Results 1 to 6 of 6
    Yakima (Hurricane) Lefty Adapter
    This past weekend I took my bike with a new Lefty out for a ride. When I went to install the Yakima Lefty Adapter for my roof rack, I could not get the screw to engage the fork's threads. Has this happened to anyone else, if so what did you have to do to correct this issue? The Lefty is a Carbon Speed SL 110 with OPI.
    Reputation: amillmtb's Avatar
    Jun 2005
    Did the wheel thread back on?
    I'm not sure, I do not remember where the original position was.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Well, if the wheel is not correctly installed, the brake wont line up with the rotor properly so...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    My wheel threads on just fine. The wheel has a Project 321 Hub complete with hub cap & bolt.
    Jun 2005
    I just wanted to make sure that the wheel threaded on. If it didnt I would have said to check the Helicoil.
    Try greasing (Park Poly-Lube 1000 is best) both the threads on the adapter and on the lefty axle.
