Results 1 to 25 of 25
    Reputation: alfa75's Avatar
    WTF!! lefty RLC FOX carbon
    i didn't believe my eyes WTF is this sticking out bended?
    after my ride today i cleaned the scalpel and did some maintenance on my lefty,
    cleaned filter and wanted to clean te bearing races and regrease them.
    when i took the boot off i saw this . did not notice anything and all working fine( lock-out, rebound, blow-off)
    i read today the post from "jon.moab " about Broken Lefty Bearing Retainer and i think
    this is what's my problem!
    i like to ride with the lock-out on and soft blow-off valve, maybe that is the cause ?
    Feb 2005
    Looks like the circlip that holds it all together, popped off. This usually happens if folks do a bit too vigorous a job while resetting the bearings.
    What you're seeing that's bent is the outer race retainer clip. Unless you plan on DIYing it, that thing needs professional help. DO NOT RIDE IT TILL YOU DO!!!
    It's in a great position to be just fine, one clip at a few dollars, and a rebuild, and you're in like Flynn.
    The riding settings you prefer, have nothing to do with this issue.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    I agree fully with Mendon, don't ride it get it fixed by someone that knows how to properly repair the carbon fork.
    What I do not agree with is that I have seen and repaired this failure on forks that had never seen a bearing reset.
    I have worked on Headshoks and Leftys going back to the mid 90's. These types of no good reason failures had me take the position of not fixing the carbon forks. When asked I tell the owner send it to Cannondale or Mendon. When the owners ask why, I politely explain that my thoughts are that carbon design is not real good.
    Hopefully the groove in the carbon tube is intact and can retain the bearings. There is a lot in the lines of dependability by having that big nut retain all the guts on an aluminum tube Lefty.
    BTW, that lower tube race is pretty well hammered.
    PK
    Quote Originally Posted by MendonCycleSmith
    i don't know the history but i did not perform a reset on this fork yet!
    do you know or can you tell what caused this? i will for sure not ride till its fixed.
    Quote Originally Posted by PMK
    PK
    i have a lefty MAX carbon SPV for more than 2 years and never had eny issue!
    so there is a groove in the outer tube inside where the clip gets? i hope there is no other damage .
    what do you mean by lower tube race?
    what is your opinion on the cause of this?
    thanks for your answers
    PMK
    PMK is offline
    My bad on saying inner race, the photo being kinda way beyond oversize had me thinking I was looking at the bearing. Again my bad, that damage is to the forks lower tube / leg assembly.
    Before I would even consider rebuilding it, I would accurately measure the depth of the damage caused by the clip and race holder.
    Based on the photos alone, I wouldn't even have you bother sending it for repairs, I'd say start looking for a fork. The inner leg is damaged, possibly the carbon leg is damaged where this may happen again, small spares are needed like races and clips, plus possibly rollers and a few other incidentals. Plus the labor.
    Not sure where you live but maybe Mendon has some serviceable stuff to get it fixed up. See if he will quote the job.
    BTW, that one gouge looks pretty deep, probably not much material left if it were blended out. Could be a fairly significant loss of structural integrity. Again get it measured. And through this, just consider, a fork is cheap considering any negative consequences.
    As for cause, you rode the bike...seriously I do not know what exactly lets go from what stress. I have seen it before though.
    PK
    Feb 2005
    Yep, I've seen it happen without any resets as well.
    I also agree on the clip design, it sketches me out. They seem to hold up for the majority, so, I dunno.....
    I do like the old nut style, wish they'd return to it.
    Not too sure on the damage though (to the inner leg) Looks a lot like grease lines to me. Is the inner leg smooth next to the races, or all chewed up?
    Most I've seen have done it once, and not again, and haven't displayed any damage if they haven't been ridden much once it's discovered.
    - FrostyStruthers
    PK
    pfff....that's not good news! i hope it's not so bad.
    i cleaned the inner leg , that was grease ! it all looks good to me no scratches (only the wear and tear, think thats normal) and very smooth .
    what do you guys think?
    Have you shop send it back to C-dale. They'll take care of it for you.
    Quote Originally Posted by Headshok'r
    i'm not the first owner and did not purchase it at my lbs (cannondale dealer)
    isn't that a problem?
    Feb 2005
    Quote Originally Posted by alfa75
    I won't say never, but I do believe that will put you in the paying for it territory.
    That said, Headshok'r is well connected, and won't steer you wrong, wait to see what he says....
    - FrostyStruthers
    Underneath the boot i found today a white nylon piece when disassembled the lefty from the frame. did not see it the other day.
    what is that?
    Feb 2005
    what is that?
    Dig deeper, you'll find a steel circlip below the nylon piece. That nylon ring functions as a barrier/spacer between the circlip and the race retainer.
    - FrostyStruthers
    I would still have it sent back to C-dale; while not warranty, they are known to work with people. They will rebuild it properly and update any thing in it that needs it. At this point in time, it's not rideable as is.
    yes found also the circlip
    @Headshok'r : i just came back from the dealer and he told me 2 things
    1) the fork is for america only and was not sold in europe? an european dealer can not claim warranty even if i had the card????
    2) since the merger with dorel things changed and is difficult to claim warranty.
    also he told me that you have to go trough a dealer and as a consumer you can not go directly to cannondale?
    i left the fork for repair, not to costly acording to him and he told me the circlip was not put proper in place at build .
    what can i do if i still want to claim warranty? who can i contact?
    thanks
    fixed
    lefty fixed! no damage found
    hope it will not happen again! surely will check after every ride
    and i did today ............after a test ride
    I heard a sound(pop) when returning home and knew immediatly that it happend again exactly the same
    i asked the lbs if the carbon where the circlip sits was ok and he said everything was good ,nothing to worrie.
    why the circlip fails? or is it anything else? now i become a little bit scared that maybe it's something more serious ?
    PMK
    PMK is offline
    As I said, I will not work on the carbon Lefty. Someone will. And if the groove is worn or damaged, the clip is not seated tightly, well you know.
    Nothing is perfect, I know, regardless of who builds your fork or works on it, keep it maintained with inspections often and lube changes frequently.
    PK
    a cannondale dealer did work on my fork ( he's trained to work on lefty's) and
    i asked him if the groove was good or no broken peace's or something like that!
    nothing was wrong according to him.
    so i bring the fork back and we have to find what is causing this? also i asked him to contact cannondale to adres the problem maybe they know what to do?
    how is the circlip locked on alu lefy?
    PMK
    PMK is offline
    No clip, big nut installed with a pin spanner.
    Not 100% perfect, but overall effective. Yes the entire leg assembly weighs more, you bought a performance / race item. Like F1, sometimes it just takes the better technicians and parts being replaced.
    PK
    The problem is not with the circlip nor the carbon tube. What has probably happened is the top of one of the outer races was caught on the underside of the damper cap. Tis fork should be returned to C-Dale in Holland for a rebuild.
    The Lefty RLC was sold in Europe...just not large quantities.
    Interesting.... tomorrow i bring back the lefty to the lbs ( who is located in holland) ! have you experiended the same problem?
    i spoke with a specialist and according to him that could be the case with another model but not with the lefty speed RLCFox 110mm!
    the never ending story
    so....last saturday i got back my lefty . did a testride and fork feeled diffrent.:
    lock-out lever was misplaced, doesn't lock at first but after compressing few times.
    and when compressing fork while standing stil, i hear a metal sound from inside tikking? think the spring!
    i bring the fork for repair and i get it even more worse back?
    but then on my sunday-morning ride it happend again:madman ! nowbody knows what the F$$$ problem is.
    fork is at cannondale now hope they will find the problem
