    Reputation: ccaddy's Avatar
    Will a Radium shock fit a Rush ?
    I might be able to pick one of these up as a cheap spare to use
    if I need to have my Rushes Fox serviced .
    Are the two the same stroke / compatible ?
    Reputation: Kevin G's Avatar
    Feb 2007
    I have one that came stock on my Prophet; barely used as I have an ISX4 on it now - PM me if interested...
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Quote Originally Posted by Kevin G
    I don't think that the Prophet shock with 200mm i 2 i will fit since the Rush needs a 190mm i 2 i.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    That's the type of info I'm looking for
    Can you run a longer stroke shock in a short stroke (sounds like a motor )
    suspension design ?
    I'm thinking that it wouldn't damage the frame but not allowing the shock to
    travel it's complete stroke , it wouldn't perform as well as it should .
    Comments ??
