Results 1 to 43 of 43
    Bike Breaker.
    Bonking ... not feelin' well Will Cannondale warranty this?
    Have had my gemini 2000 04 for five months now and was awaiting a lighter spring which was a difficult size to get, up until then used minimum preload, and the bike at 150mm so I get it last week so I decide to fit the spring and at the same time increase the travel to the 170mm setting, well first problem that happened after following and old picture which showed the shock with resovoir pointing down first run ended in a den in the down tube, I was gutted and felst sick, then the only other way was resovoir in the up position, all other two ways couldnt even fit, well after today the shock is now hitting the top tube and every time the shock compresses into the last bits of compression it takes a small chunk out of the top tube. Phoned the bike shop and the bike is being seen on Tuesday.
    What should I expect them to do as the swinger coil 4-way shouldnt be fitted to a small gemini?
    New frame and shock? (obviously would have to be a fox, although I have had fox before and really dont want that.)
    Ask for the DH frame and only have 170mm
    Will they change the whole bike?
    Should I get a diferent make (again, love my gemini)
    The Heckler, Bullit, G-spot would be an option, but would I get the full amount in money spent back?
    What will they do?
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Whatever you do, be honest.
    I am not sure how Cannondale will handle this one. You fitted an aftermarket shock, without checking for clearance. (A shock specifically restricted by Cannondale.)
    I am sure that they will work with you, but it depends on many factors.
    At the very least, there is a warranty/exchange program, and you will have a few different options.
    Good luck, this is a tough one to call.
    Do you have photos?
    gfy
    Bike Breaker.
    Bonking ... not feelin' well Swinger coil
    The shock came with the bike, I had sent from answer a spring for it which I changed.
    Jun 2003
    How bad is the damage?
    Worst case scenerio is that you end up buying a new front triangle. Hopefully Cannondale sees fit to provide you with a new warranty triangle. Good luck.
    gfy
    Bike Breaker.
    New question here. New triangle
    Trouble is I reckon it would still be a small frame with the same shock, unless mine was an early release and then they noticed.
    I would like a whole new frame. The trouble I have had from the begining the bike came with a 500lb spring which suited someone of about 180lbs im only 140, and eventually got a 350 although they could only get a x2.5 instead of x2.25 until they made more 2.25 springs, so when I went to the 170mm setting then thats where the real problems started.
    So if it cant be resolved with a raw silver small frame then not sure what I might want, the bike cost me £2600 which in the states makes it appx $4200, as you can see from that amount of money its a lot to have a non 170mm bike sat idle at the mo.
    could get a stinky, coiler, cove gspot, heckler, or even a DH gemini frame. I'd want six inches minimum and with possibly a 05 marzochi, will know the outcome in 24 hours. I want a coil shock though and the 05 bikes arent here until 6 weeks.
    Bike Breaker.
    Lates news
    Quote Originally Posted by catnash
    So if it cant be resolved with a raw silver small frame then not sure what I might want, the bike cost me ?2600 which in the states makes it appx $4200, as you can see from that amount of money its a lot to have a non 170mm bike sat idle at the mo.
    Took the bike in today, Cannondale want a photo and I have let my bike shop deal with it all, looking like I will get a new frame and a new 05 shock by 5th element, the silver raw colour I loved so much isnt available in a small frame any more so I might get the newer 05 2000, but there may be a chance I may get any colour, but the guy at the shop said they will most probably give me a choice of colours, So I am waiting for two to three days to hear the outcome. To be honest I don't want another make, I just want the fun again. I thought my gemini as good a bike as any.
    Jun 2003
    glad to hear it.
    I am glad that Cannondale is standing behind the consumer. Keep us posted, including photos of the new ride.
    gfy
    Bike Breaker.
    Latest news
    Well heres the latest
    six weeks wait for a front triangle and shock in the 05 coloured 2000 model, bad news is that that doesnt include the rear part of the bike so would have diferent coloured rear which I couldnt be happy with, they have allowed me to 'buy' a 05 rear part for $450
    The dealer has asked me to e-mail cannondale in the states but really don't know how to ask for the rear for free.
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    My best riding bud has a gemini and you plain and simple mounted the shock wrong. Your lucky Cannondale did anything for you. My friend also cracked his swingarm and they sent him a new one sight unseen (but he works in a shop).
    -TS
    Fayetteville, AR and N.W.A RePrEsEnT
    Bike Breaker.
    Bonking ... not feelin' well Nope
    No the shop has had a look at it, the small frame that I have has the swinger 4-way coil shock, In the resovoir up front the shock wont fit in the resovoir at the back the shock hits the frame in both position which means the small frame has a fault with the swinger 4-way coil shock. The pdf file I had dowloaded didnt have the pictures for shock settings in the small frame size.
    Uhhhhh...
    Damn, if it doesnt fit in any position what so ever, i'd be pissed. Sorry for doubting you but my friend has some dents from wrong positiong. Have you tried resovoir up, towards front of bike? That's the way 5th E run and u can maybe stick 2 pieces of paper in the space.
    -TS
    Bike Breaker.
    doesnt even fit
    Only fits in one way in the 150mm setting. but cant even get the shock in with the resovoir up front in the two positions, the first dent happened when I had the resovoir out back and facing down as fox would have on my old manual, that dent was big and I felt sick when that hapened, so I changed the shock to the resovoir up top and there appeared to be space for it to go but in its last 3/4 trabel hits the top tube. Even before this I had downloaded pdf file with the updated gemini pictures with the swinger coil but it doesnt include a small frame in that description. I had heard about potential damage with shocks and frames, Should I be paying for a rear to match the 05?
    Jun 2003
    Call them yourself.
    Get your RA# from the shop that you are working with, and call cannondale directly.
    Does the color work?
    gfy
    Bike Breaker.
    The colour
    Nope, the colour to me wouldnt look right. what is the CA number?
    Sirstopsalot
    Cannondale Bicycle Corp
    16 Trowbridge Drive
    Bethel, CT 06801
    PH# 1-800-BIKEUSA
    1-800-245-3872
    email
    Jun 2003
    Do you mean RA#?
    The RA# is Return Authorization. This is a tracking # that most companies will use to track repair/warranty cases. Having your RA# might make the call easier, as the person on the Cannondale side will have the info provided up to the time of the call in front of them.
    gfy
    Bike Breaker.
    Cool-blue Rhythm Latest
    Should I send this link to Cannondale as well? or has anyone else done a similar thing?. I have asked for the RA number so awaiting that. I am starting to save up for the rear triangle, I will most likely pay for it myself as I want it to match. One way for me to cut some of the costs is to sell the thru 12 rear on e-bay, but unlikely to ship anywhere far. The more I have thought about it the more I have finally found all the attributes I wanted in a bike and any other bike won't do. At least in appx five weeks would have had a new frame and shock which should then see me right for the next few years. One thing I'm going to do is spend just a whole day on a small track to try to find the sweet spot in the front breakout fork. In the UK we deal with Cannondale in Holland, I can't deal direct with the USA, and I think they ship in batches. I have a cheap hardtail with rim brakes and a very cheap Marzochi for which at least will get me out on the trails.
    I just like the idea of single pivot.
    Jun 2003
    Glad to hear you like the bike.
    Even with the teething issues. I may have been interested in the thru12, but after shipping and what not, I can Pro-deal a new one for very little.
    I am going to PM you with some info that may make the sale of the old swingarm easier.
    gfy
    Bike Breaker.
    ... and if we just ... latest news
    well, decided to pay for the rear awaiting it to come to europe in about five weeks, the rest of the frame front triangle is new and the shock will be new. upgrading the hayes lines to goodridge hoses, the same as in formula one cars.
    Bike Breaker.
    ... and if we just ... More latest
    Just heard that the frame will come with the Progressive 3-way coil shock, which I should be pleased with as the british importer TF Tuned I have very good dealings with. And unlike the fiasco in trying my best to get the right weight spring with the swinger 4-way.
    The new colour is this:
    http://www.cannondale.com/bikes/05/ce/model-5VG2.html
    What do you guys think of this years silver?
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I would have to see it in person but from the picture, I like it. It looks more bronze than silver.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Bike Breaker.
    Good job! It's growing on me.
    The more I look at it the more it's growing on me, the progressive 3-way shock is new for this year, Just talked to my lbs store and told that if I'm lucky its four weeks, otherwise its five.
    the shock is on this pic.
    http://www.pinkbike.com/modules/phot...w&image=129755
    Does this mean that Cannondale screwed up by issuing the Manitou Swinger 4-Way on the small 2004 Gemini frame?
    Bike Breaker.
    New question here. Swinger coil 4-way
    They haven't said that I can only assume it had, If I would have asked the bike shop to put it in 170mm setting then it wouldnt have left the bike shop, trouble is I have heard great things about the swingers, less so about progressive.
    Bike Breaker.
    Bonking ... not feelin' well Prophet
    I'm half tempted to ask if they'll give me a prophet 2000 instead as its the same colour as i liked so much, not sure whether they would allow that though,
    Jun 2003
    They will allow it.
    THere is a warranty upgrade price for that frameset. Contact your dealer. What color is BTC? That is what is available. You can also get the Prophet 4X frame, with the thru-12 axle if you want.
    Check your PM.
    gfy
    Poser
    Reputation: direktor's Avatar
    Quote Originally Posted by damion
    THere is a warranty upgrade price for that frameset. Contact your dealer. What color is BTC? ]
    Black tinted clear.
    Jun 2003
    Very good.
    Quote Originally Posted by direktor
    Black tinted clear.
    So it is the 2000 frameset.
    gfy
    Bike Breaker.
    ... and if we just ... Yeah 2000
    Yeah mine was the 2000 model, looking at the bc colour it's difficult to exactly see what it looks like, though I can see myself falling in love with it as soon as i see it.
    Sirstopsalot
    I tryed and they would not alow it
    Bike Breaker.
    New question here. Oh well.
    According to this website set the question 3 weeks ago so amy have two weeks left to go if I'm lucky. Still don't know how they will make the progressive 3-way fit, if anything its the same size as the manitou swinger.
    Bike Breaker.
    Bonking ... not feelin' well Still waiting
    Maybe might hear something next Monday, but there's no guarentee. It's such a great bike that I'm happy to wait, I suspect the wait is in most part to being next years model and in small?
    It looks like Cannondale screwed up on your 2000. It should have come with the 5th Element. See this:
    http://www.cannondale.com/Asset/iu_f...ini_shocks.pdf
    Bike Breaker.
    ... and if we just ... I knew it!
    Cheers
    I have sent an e-mail to my shop asking for the rear for free again, as It now shows that the small frame shouldnt have come with a swinger coil? I like Cannondale and don't want to mess them about about this, but if I have the rear for free that would mean I could upgrade other parts quicker.
    Bike Breaker.
    Bonking ... not feelin' well Longer to wait
    Cheers
    I'm still none the wiser today, now have a bad back and sore hands from the other bike. I wish I knew a date.
    Bike Breaker.
    Upset Thw wait goes on
    could well be anyday but some sites have stated 12/12/04 so in total would have waited 4 months. Losing faith with it all now. 4 months for a warranty replacement, thats really bad.
    Jun 2003
    Have you called Cannondale directly?
    What does Cannondale have to say about a 4 month wait?
    I do not EVER remember a customer having to wait 4 months for anything. If it is more than a week, my boss is all over the phone, finding out WTF is going on.
    gfy
    Bike Breaker.
    ... and if we just ... It's on it's way.
    Just had a reply a few minutes ago to say the frame and the 3-way shock is on its way to my bike shop, that will be there possibly monday and I might have to have them post it out on to me. so its been 10 weeks. Still will have to pay for the rear it looks like it. If I had spotted the problem straight away the bike would never have left the bike shop and would have ended with a Santa Cruz Heckler.
    Bike Breaker.
    ... and if we just ... There's a fault on the file as well.
    Quote Originally Posted by racerzero
    If you have a look at the small frame in the pictures you will see the same bolt hole used for the 150mm and 170mm setting. Very confusing...............
    Good Catch!!!!
    Looks like Cannondale will have more warranty work to do if you follow their own official instructions and damage the frame from shock contact.
    Bike Breaker.
    ... and if we just ... First review.
    Well the box came on Thursday morning, not enough time for me to put it together and set up my trailtech UK HID lights. The first impression was again the quality of the frame, you know Cannondale frames are superb, the colour BTC looks more bronzeish on their website, I had to buy the rear 05 swing arm to match and it isn't a million miles away from the 04 version I am supposed to have been returned to me as a spare. the amount of clearcoat is more and its finished in a lovely smmoth finish. Last years wasnt disimilar to galvanised finish.
    The shock is a Progressive 5th element 3-way and at last the bike came with the right spring weigh for my weight, last years came with a 500lbs spring which meant you had to be near to obese in the small frame height range. The bike performed perfectly on its first outing like all bikes should and only needs small adjustments to the rear shock. The bike is more balanced with the correct weight spring, I was forever losing the line at speed on singletrack with the old swinger coil. on climbing with the rear set on 170mm and the breakout + set down for climbing i was going up climbs as easy on my 04 s-works enduro. and thinking about it better.
    So at last I am happy to have the bike I wish I had from day 1 last time. I am glad I didnt have it swapped for the Prophet 2000 as with a bit of weight saving i can get it down to 32lbs and a bit below without losing any of its burliness.
    What spring rate did your Manitou Sherman Breakout Plus come with? Did you have to get a lighter spring for the fork too?
    Bike Breaker.
    Weight spring
    The manitou came with a 500 spring i needed between 350-400
    Yeah I had to change the spring from the stock firm on the breakout to the lightest, so spent a bit on springs. luckily my tuner gave me a refund on the one from him.
  1. The Ellsworth Warranty--the rest of the story.
    By Tony Ellsworth in forum Ellsworth
    Last Post: 02-10-2005, 01:28 PM
  2. The Cannondale F2000SL 05' and I need YOU
    By sacre-coeur in forum Cannondale
    Last Post: 09-05-2004, 11:29 AM
  3. check out Tony's reply to his warranty issues!
    By damion in forum General Discussion
    Last Post: 04-01-2004, 01:42 PM
  4. FSA BB warranty?
    By Crash_FLMB in forum General Discussion
    Last Post: 03-10-2004, 08:59 AM
  5. Replies: 17
    Last Post: 02-13-2004, 04:23 PM
