Results 1 to 2 of 2
    Will this bar fit on my 07 F4?
    http://wheelworld.com/itemdetails.cfm?id=5343
    I was thinking of upgrading my bars, but not sure of my diameter. Also, are these riser bars and if so what is the rise?
    My stock bar is a 20mm rise. Sorry for the newbie questions~
    All recent Cannondales use the 31.8 mm clamping diameter standard for bars. The one you pointed to is 25.4. So it will not work unless you either get a shim (I don't know where you can get one, but I know that they are available), or replace your stem.
    Quote Originally Posted by ruer
