Results 1 to 5 of 5
    Reputation: fueledbymetal's Avatar
    Whine from new lefty hub?
    I have a new wheelset with a new Lefty hub and took it out for the first time today. After about 7 miles or so I started to notice a whine from the front hub. The pitch changed with speed but only happens while I'm on the bike (it's silent when I hold the bike and spin the wheel by hand). Any ideas?
    I just bought a new set of Crossmax ST's and the front hub did the same thing. I very carefully sprayed a bit of WD40 around the axle bolt to lube the O-ring and it went away.
    Cool, I'll try lubing the O ring and see how it goes...
    Reputation: Kayba's Avatar
    Quote Originally Posted by fueledbymetal
    I had the same problem on my first ride too. It appeared that the O-ring was jammed between the hub cap and the bolt. Some lube should help. If it doesn't, take the O-ring off. The only drawback of that is that the bolt rattles in the hub when the wheel is not mounted on the Lefty.
    Kayba
    narCOTIC
    Reputation: Hadouken*'s Avatar
    Nov 2007
    HA HA!
    (childish i know)
