    Reputation: chick0's Avatar
    Where to get RIZE suspention Bearings ?
    Just stripped down the rear suspension on my Rize, and found that the linkage and main pivot bearings could do with being replaced.
    The only place in Europe i have found the parts online is http://www.cannondale-parts.de/
    They seem to be rather pricy, as there looking for 61 euro ( $75) delivered to the UK , for the 6 link bearings and 2 main pivot bearings.
    here is the part codes;
    KP073 - linkage bearings
    KB61902 - main pivot bearings
    Does anyone know where i could pick up these bearing cheaper? Or if there is some generic bearings that will fit?
    Thanks..
    Charlie..
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Quote Originally Posted by chick0
    Thanks..
    Charlie..
    Go to:
    http://www.enduroforkseals.com/id138.html
    Make sure you measure your old bearings....
    G8 bearings, way better quality than OEM (and cheaper!)
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    You need 6 x 6800 and 1 x 6902 bearings.
    I found the official price of SKF bearings:
    - 61800-2RS1 = 20.70
    - 61902-2RS1 = 21.95
    Total = 6 x 20.7 + 1 x 21.95 = 146.15
    @ Dr. Cannondale:
    1 x piece Lefty hub bearing small & pivot axle Rize Rush Prophet 12.00
    1 x piece KP073 22.00 22.00
    Subtotal 34.00
    Delivery method DHL
    This Service is only available in Germany 5.00
    Total = 39.00
    I think the prices aren't so bad, the quality of the SKF bearings are super, but are they 3 times the standard Cannondale bearings price worth it?
    Quote Originally Posted by rumble101
    @ Dr. Cannondale:
    Subtotal 34.00
    Delivery method DHL
    Total = 39.00
    If they last longer, yes.
    You shouldn't need to take apart your suspension and replace the bearing every 6 months.
    Also look at Phil Wood bearings, they are tough. Now if only Chris King would make suspension bearing with a 5 yr warranty, then we would be set. Maybe I will suggest that to him at Downieville if he is there this yr.
    Lead by my Lefty............... right down the trail, no brakes.
