Results 1 to 7 of 7
    Reputation: ccaddy's Avatar
    What weight fork oil in the Lefty ?
    I have my Lefty DLR2 apart but for reassembly I need some Phil's Tenacious Fork oil .
    This according to the rebuild info I have from Cannondale .
    Three questions :
    1) Phil's is not available in my area .
    While looking in a LBS , they had one container (don't remember brand) that was
    $36 and another that was $54 (WTF)
    If lucky , they were one litre bottles , if that .
    2) Can you not just use motorcycle fork oil of the same weight ?
    They definately will not be even close to costing this much .
    3) What weight of oil is used in the Lefty ? I know some of it is based on rider
    weight and riding style but I can't find any charts that show this .
    HELP .
    RLM
    RLM is offline
    Dec 2005
    This won't answer all your questions, but it may help you make a decision...
    http://forums.roadbikereview.com/sho...highlight=phil
    Golden Spectro Very Light (2.5wt).
    Very interesting .
    Just like the car oil debate of premium oil vs . no names
    Same arguments , just substitute the industry
    Sorry , I just realised that I asked the wrong question .
    I don't need dampening oil , I need this oil for reassembly of the
    air piston assembly .
    It's more or less just a lubrication for the seals in the air chamber .
    I ended up getting some Fox shock assembly lube at LBS .
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    Quote Originally Posted by Jerk_Chicken
    i have a lefty serivce manual for speed dlr2 forks. i was looking thru it since i am going to swap my neg spring for a lighter one.
    the manual calls for 85/150 oil so that would be 5 wt oil. i am thinking of going with 125/150 (7.5 wt) because even with my rebound set at the slowest setting it is still abit fast (my fork is converted to 29er, limited to 80mm instead of 110mm, so i am sure it has something to do with quicker rebound).
    i think a liter of golden spectro sells for about $20 at most motorcycle shops.
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    I recently posted something about how there's ambiguous labeling with Spectro oils.
    Check out the pics here:
    Golden Spectro: Synthetic Blend or Full Synth?
