Results 1 to 5 of 5
    Reputation: brentos's Avatar
    What Si Crank Spiders are available?
    Hoping to set up some drivetrain options for the bike I have on order. (1x10 and quick change to 2x10) I'm not sure the Cannondale tech docs are up to date.
    It will come w/ the spider for XX rings. (26,39) 80mm-120mm BCD.
    What other spiders are available? Triple vs. Double, 4 bolt vs 5 bolt, BCD?
    Hoping for a comprehensive list so I can hash out my options. But I'm hoping for a 4x104mm triple, to set up the 1x10 with a chain guard and centered chainline.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    you wrote for 1 x 10
    i did it with a 110mm BCD spider , compact road spider and a 36T oval rings from Rotor Spain ciclocross ring, mounted internally
    can do it with a 130mm road spider too ... limit is the ring teeth size only
    however also there are :
    5 arms 94mm BDC spider , double 40 up to 44 as big ring , 29T as minimum as little ring
    5 arms 94 -58 mm BCD spider , triple or can be used as double using a 20T as minimun as little ring . very rare , older triple standard until 2003-2004
    4 arms 104-64 mm BCD spider , triple or can be used as double
    4 arms 120-80 mm BCD spider , XX rings only , 25T as minimum as little
    obviously i have at least one piece of every type
    FIRENZE rulez !!
    here pics on 29er and on Scalpel
    sorry for not using chainguard , but mine are few days trying
    Attached Thumbnails Attached Thumbnails What Si Crank Spiders are available?-hpim0593-custom-.jpg
    Thanks Eliflap.
    I'll likely go with the 5 arm compact road or the 4 arm 104mm triple. Depends on chainring availability.
    N'Gear jump stop on the inside & Spot Brand chain guard in place of the big ring.
    Thanks again.
    FIRENZE rulez !!
    please consider this point too:
    spiders has different offsets ( i not wrote in previous message but for 94mm double there are 2 versions , for 68 or 73mm BB shells ) and frames has differents chainstays width too...
    so sometimes you cannot have a successfully set up as you want...
    for example :
    Scalpel carbon with 4 arms 104-64 mm spider , modified as double .
    max bigger ring in middle position is 38 or 39T ( sorry not remember well, maybe Kayba can helps you well in this point )
    installing a 40T or bigger , you hit the chainstays ...
    consider a no spider combo ... here in Italy at least 4 companies produce that type of combo as picture ... installing only the bigger ring for 1 x 10 with a shoter spindle for correct chainline maybe can be another way to have your set up
    Attached Thumbnails Attached Thumbnails What Si Crank Spiders are available?-hpim0839.jpg
