Results 1 to 32 of 32
    What do you guys think of this hole in my new bikes weld pics included
    Its a brand new 2011 Quick CX 3. Love it but looks like this was missed during qulity control. its on the inside of the left seat stay.
    I've done some reaearch and I believe its called a "wormhole" in welding terminology.
    not sure what to do. I did accept it this way from LBS but I am concerned it could be a weak point or stress point and be a safety issue.
    (the bike)
    let me know what you guys think.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    I'd be taking that right back to the shop for a warranty replacement.
    Less isn't MOAR
    ballbuster
    Reputation: pimpbot's Avatar
    Second that
    Quote Originally Posted by Sideknob View Post
    I might mean you are out of a bike for a couple weeks, but I would warranty it.
    really warranty it why? can you guys explain I am a beginer.
    Can't stop the Prophet
    Reputation: brows141's Avatar
    If it is new and under warranty take it back and get a replacement. Just because you "accepted it that way" doesn't mean that you are at fault or that you have to keep it. The hole may be there for years without any problems and then again it might not. It would really suck if lets say that weld fails right after the warranty period is up. Then my friend you will be $h!t out of luck.
    Why would you even be thinking of keeping it being that it has a manufacturing defect???
    Having painted a couple of my own novice welding projects maybe they thought the paint would cover it up.
    By the way is it just me being paranoid or do the welds on the new Cannondales look uneven and not as uniform as the HMUSA welds?
    I do not want to start the whole discussion again with this post! Just curious.
    Take it back, if you have a hole in a weld like that it becomes a weak point in that joint and is more likely to fail there. Warranty should cover that one no problems, shiney new(er) dale on its way to you.
    Tool
    Reputation: Pedalphile's Avatar
    Quote Originally Posted by Ice Cold View Post
    I don't think it's so much the effect of the tiny hole as it is what caused the tiny hole to be there. It could be a sign that other parts of the weld are weak. Good welds shoud not have holes in them.
    I can barely get my mouth around it.
    Quote Originally Posted by brows141 View Post
    Very good point and you have asharp eye. about the welds this is actually my second bike of teh same make and model year the first one was replaced last month because I took pictures of the "cannondale's smooth welds" and emailed it to Cannondale/ Dorel they were so lumpy and bumpy they exchanged the bike. Now this one, the welds are better smoother but it has this "wormhole in welders lingo. which can be an issue. I accepted it this way because I thought it was cosmetic but it seems to be a bigger deal.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    A little bondo and touch up paint....
    JK. Take it back. Maybe the shop has the same model and size and will simply swap it out for you?
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Cannondale says no they've seen pictures its my second bike now. Its only cosmetic "they say".
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Welcome to the "New Cannondale".....
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Reputation: mfisher1971's Avatar
    Dec 2005
    maybe if they would have just gotten it right the first time...
    so if i were to stab someone in the thigh, it would only be cosmetic according to that logic.
    i've purchased my last cannondale. i'll look for a US manufacturer when the time comes.
    trust the tread
    '06 Cannondale Prophet 1000
    Dec 2009
    I work in a sheet metal manufacturer and have been in the industry for 21 years. Pourosity in welds has never been an acceptable quality issue and is always red flagged and rejected. It basically indicates a strong potential for weakened welds and a much higher portential for failure. Second bike or not, it should have been caught by quality control and held back. I would force the issue on the return and ask them to replace the frame double quick.
    Not everyone can be an expert in welding and Cannondale should take this frame back no questions asked. If the local representative has refused your request go above his/her head and deal with someone who realizes the potential for a severe injury to occur... Must I mention lawsuit...
    Just my two cents.
    Aug 2010
    I had to get a replacement for my 2010 flash 29er frame and got a 2011 Flash 29er replacement..... 2011 frame looked a little sloppy, lets just say that on my 2010 USA frame i didn't even know it was more than one piece of metal.
    Ridin' dirty!
    Quote Originally Posted by mfisher1971 View Post
    LOL too funny...
    It would help if this got more mindshare Twitter or Facebook. To get their attention just not shure which email to send it to at Cannondale/Dorel corporate.
    Is it too late to simply take the bike back for a refund?
    Because, quite simply, it's not right. It's not "cosmetic" at all - it's structural. Cosmetic would be a paint defect.
    Cannondale pride themselves on quality aluminium frames - that is not a quality bit of work right there. It's a potential "stress riser" where forces can be focused on that one defect, leading to a potential frame failure. It's not meant to be that way - I wonder why the shop even offered it for sale if they knew the defect was there when you got it? Is that what happened, or did you find the problem later on?
    Less isn't MOAR
    Quote Originally Posted by Rize View Post
    Just my two cents.
    If I remember anything from a welding course I took 15 years ago, wormholes are usually caused by overheating the weld. When the welder is laying/pushing "the bead" if too slow a motion or too high a welding setting is used then the metal is overheated and the weld collapses on itself creating the wormhole. Either way it is not a cosmetic issue and any dignified welder would not try and pass that off as it is unacceptable.
    Press the issue and insist in an upset but controlled manner until you get the result you deserve. You paid money for the bike and it's warranty and this is unacceptable. They can say whatever they want to try and get out of giving you a new frame. It appears that this is a new Cannondale tactic, but it's just poor customer service. Look through the threads and you will see similar stories of members having to deal with the company.
    Persist is the only way to get results.
    Done:
    https://www.facebook.com/pages/Canno...ref=ts&sk=wall
    https://www.facebook.com/RideCannondale
    Quote Originally Posted by Moozh View Post
    Well LBS said no refund because its not a model they normally stock, and this is the second bik enow which I accepted with a hole, which they should have warned me against but they both say its only cosmetic.
    The first bike was completely replaced after I emailed Cannondale/Dorel pictures of its lumpy and bumpy welds. The welds on this one are noteably smoother but worlds away from a 2009 model.
    I just need to find a good email address for Cannondale/ Dorel customer service etc. Regional rep has turned me down saying its only cosmetic. The rest of the welds look good.
    Most likely it was missed during quality control (its on the inside of the seat stay)
    I say take a drill into your LBS and start drilling little holes in the welds on owners bike until he agrees to take it back. That should do the trick. :-)
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Not to Hijack the thread but OP thanks for the thread! I did not know this bike existed! now I have another bike on my list of possible candidates for my new commuter!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    Quote Originally Posted by ae111black View Post
    No joke its a great bike, its quality despite the obvious issues here. I thank Cannondale they already exchanged one identical bike because of "impreferfect" welds they were not "smooth" enough.
    I've now had 60 days to tryout this model and I love it. the wheels rims 700cx37 hold my 250lbs easily its smooth rolling and fast.
    It comes with knobby Continental Double Fighter II's for light trail use. Which would be fine nothing more than light trails.
    I added my own "Slicks" Continental Sport Contacts for even less rolling resistance.
    The Disc brakes Tektros are fine for my use, and weight wise its pretty good in a Small frame I guess 28lbs or less. Its all white with the all black wheels rims I get compliments on it every time I ride from perfect strangers. And for $600 I got a great deal from LBS.
    I Have Cookies
    Dec 2008
    I plan to put drops on it.... Looks sweet!
    ____
    Kimo
    Reputation: qwackers's Avatar
    Aug 2005
    Quote Originally Posted by cdalemaniac View Post
    Agreed....Thatd never of passed inspection i n the "Handmade In The USA" days....
    2002 M Cannondale Jekyll Goodboy 30th Aniversery...#017-300....
    Aug 2005
    Agreed....Thatd never of passed inspection in the "Handmade In The USA" days....
    what are drops??
    Ride long, ride hard.
    The Cannondale frames are not what they used to be. I believe they got rid of 150 welding jobs (plus many other jobs) when they shut down the American manufacturing. It's ashame that a company like Cannondale sold out to corporate America and are now part of Dorel who makes Big Box Mart bikes.
    What was the outcome of this issue??
    Let us know!!!
    nothing yet.
  1. Ti weld pics.. what say ye
    By Schmitty in forum Frame Building
    Last Post: 11-23-2010, 05:15 PM
  2. New fork has a tiny hole next to a weld?!
    By norcom in forum Frame Building
    Last Post: 06-09-2010, 04:30 PM
  3. New V-10 - X-Post (Pics included)
    By .thumper. in forum Downhill - Freeride
    Last Post: 11-21-2005, 09:10 AM
  4. Riding with J... Pics included...
    By screampint in forum Passion
    Last Post: 06-26-2005, 05:14 PM
  5. Hole in Turner weld?
    By theTnT in forum Turner
    Last Post: 02-26-2005, 01:55 PM
