Results 1 to 7 of 7
    May 2010
    What 29er frame size ?
    Looking at a cannondale F-29er1 and was wondering what frame size - I am 5'10".
    Thanks,
    Mike
    Reputation: valiant1974's Avatar
    My guess is that you'll need a size M frame. I would suggest test riding both the size M and size L just to be on the safe side.
    I'm 6' with a 32" inseam and I ride a size L myself...
    '15 Niner RLT 9
    '13 Pugsley Necromancer
    '13 Bad Boy 5
    '09 F29 2
    '08 Rush SL 5Z (650b)
    '00 F2000SL
    I'm 6-2 6-3ish 32inch inseam and ride an XL. I went down to a 100mm stem vs 120. I could probably ride a large though.
    Reputation: amillmtb's Avatar
    Jun 2005
    I'm just under 5'10" and plan on buying a Medium F29er 1. I would say that you should have your LBS look at your on the bike to make sure that it is right for you because every person fits differently.
    Aug 2005
    base the size on the TT length, and standover second.. You can always adjust the seat post, but the changing the stem for fit effects the turning/handling/ balance of the bike.
    good ski/bike deals at www.mntlion.com
    My life is better than your vacation.
    Reputation: skinl19's Avatar
    I am just under 5'10" but ride large F29's. I have a longer inseam and usually run a longer seatpost and high rise stem.
    I'm 5' 10" with an inseam of 32" and ride a medium flash 29er 3
    Seems to fit fine I would'nt want to go to a larger size
