Results 1 to 2 of 2
    Weirdness with Lefty SL lockout
    Hi guys and gals,
    I just picked up a distressed Lefty SL that I plan on having rebuilt. The lockout doesn't work in a way that I've never seen before.
    If I compress the fork suddendly (high speed compression), it locks out close to immediately - say 5mm of travel, with a bit of a clunk.
    If I compress relatively slowly (not painfully slowly, but not super-fast), it doesn't resist at all. Feels like an unlocked fork.
    Normally, when I see failed lockouts, I've never seen lockout working under high-speed compression only. Also, usually there was signifcant compression damping when in the "locked out" position, even if lockout wasn't fully working.
    Any thoughts?
    Feb 2005
    Quote Originally Posted by almontebarnes
    Any thoughts?
    Sounds like a tired seal on the lockout piston. Oil is weeping past it slowly, hence the slow compressability.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
