Results 1 to 7 of 7
    Reputation: poorboy006's Avatar
    Wanting Lefty for a Superfly build...headset issue
    Just curious if anyone has used a lefty on a superfly. I want to use the 1 1/8 c-dale lefty steerer with a pbr. The bottom of my superfly has a press fit 1.5 lower bearing. The cups are molded into the frame. I do not want to use a conversion crownrace. Any one know of any 1 1/8 adpaters that has an OD equal to the OD of a 1.5 bearing?
    Feb 2005
    Unless you have already, talk with Jake at Project 321. The best conversion units out there, and likely, the only one that has a chance of working well for you.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Thanks for the info....I hear you are the wiz with lefty's Mr. Cyclesmith. Do you by chance know where a lefty PBR conversion to a 29r PBR thread might be lurking??
    Feb 2005
    Quote Originally Posted by poorboy006 View Post
    I'm sure there's one around somewhere.
    You just need a kit for a Solo Air Lefty, a Castle tool, and a very careful, well informed approach.
    - FrostyStruthers
    All the parts will be direct from cdale including the tool. I just like to measure twice and cut once..... I will keep digging around the forums...cheers!
    edit - found info!
    Lefty PBR 29er conversion
    After reading through the above linked post, many seem to use elastomers as air chamber spacers. Is this different from what c-dale would supply? Is one a better Idea than another? Are cane creek thudbuster elastomers the only elastomers if so?
    Feb 2005
    Stock volume reduction is achieved through the kit sold to you. If you want a more progressive feel, further reduction is done via bits that Cannondale sells, or by things like the elastomers.
    I've had several customers have good luck with plastic wine corks too, so just think softish material that is stable with regards to oil etc. Get creative!
    - FrostyStruthers
  1. superfly headset issue
    By dinutz in forum Gary Fisher
    Last Post: 03-16-2011, 10:34 PM
  2. lefty on a superfly 100?!
    By N2B in forum Cannondale
    Last Post: 02-06-2011, 11:30 AM
  3. Wanting to Build a Nomad: Too Flashy?
    By ferozoso in forum Santa Cruz
    Last Post: 09-04-2009, 07:59 PM
  4. wanting to build I9 wheelset
    By superspec in forum Wheels and Tires
    Last Post: 07-06-2009, 07:40 PM
  5. Im wanting to build a DH/FR/DJ hardtail
    By kitsapfreerider in forum Downhill - Freeride
    Last Post: 12-04-2007, 10:04 PM
