Results 1 to 8 of 8
    Want to go rigid
    I just want to ask my fellow cannondale bike users for advise. I have the 2011 cannondale trail sl 3 and I wanted to replace the stock rst deuce fork with carbon rigid, I've seen on internet that rigid forks have straight and tapered steerer. So my question is which should I buy and do I have to replace my cane creek stock headset and which one and also what size of the fork to buy. Thanks in advance.
    Ps.
    I can bring the bike to my lbs buy they are charging twice the price of the fork compared if I buy it online and install it myself.
    Sent from my HTC Sensation 4G using Tapatalk 2
    Dec 2011
    Search my posts...I have done this already with a Niner carbon tapered fork.
    Did I catch a niner?
    Lip inside 09 29er 2 headtube causing issues
    So I am putting together a winter build and am putting a Muk fork up front. Anyways did some research (not enough I guess) and got a FSA Pig reducer headset. Well anyways I now noticed there is a lip on the inside of the headset and the headset is simply too long and will not press. Now I do see the Orbit Z has a shorter stack height and was wondering (before I make another mistake) if this headset will in fact work before I pull the trigger.
    After I could not get it to insert I did take it to a shop just to make sure it was me causing the issue and they confirmed what I had also.
    Also I noticed the pig comes with these inserts that just reduce the 1.5 headset down. Could I save some cash and get a 1.5 FSA headset (that works) and just drop those in?
    https://www.dollarshaveclub.com/ref/...A0CC/s/tx/cx/1
    Quote Originally Posted by buSSalo View Post
    I've seen the inner fork is for 29er will it work with my trail sl 3 26er.
    Ans if does work will it mess up the geometry?
    Thanks.
    Dec 2011
    Sorry...I assumed you had the 9ner, My bad.
    It's ok, I should have told you when I made the topic. So can I still use the niner fork or should I just get a different one.
    Dec 2011
    find a different one bc the geometry will probably be way off.
    Thanks. Guess ill try those Chinese made ones.
Hot Deals
Contests
Latest Mountain Bike Articles
