    Want bar ends, need end caps??
    Hi All,
    The grips on on my new (to me) '06 F600 are the closed-end variety. If I want to put on bar ends, I will have to cut off the grip end. No problem there, but I will also need end caps at that point, correct? I wouldn't imagine that there are end caps under the closed-end grips, but just wanted to ask here....
    Thanks,
    Howard
    I think end caps should come with bar ends.
    Reputation: Idlefrog's Avatar
    May 2005
    I think it is very unlikely that there will be bar end plugs under your closed end grips, that isn't normal.
    If the bar ends don't come with end plugs then I wouldn't be surprised if you LBS had some old ones lying around that they would let you have for free.
    Idlefrog
    2008 Trek Fuel EX8
    2006 Orange P7 Pro
    Reputation: I Like Dirt's Avatar
    I did the same on a Scott P3 and there were caps under the closed end grips!
