Results 1 to 2 of 2
    Using 190mm e2e shock on Rize
    Anyone done this?
    Does the tire rub on the seat tube?
    The shock is 200*50, so I was wondering if a slightly shorter e2e shock could be subbed in to slacken angles.
    Also I am using the RP2 on the frame, and not 100% satisfied with suspension action, too little platform with it off, not enough with it on. How do the new Monarchs they are now speccing on the Rize perform relative to the Fox?
    In case any of you are wondering the answer is no, i let all the air out of my shock last night and there is maybe 5mm clearance between tire and seat tube.
    Pity because the slacker angles with 10mm less e2e looked nice.
