Results 1 to 2 of 2
    Trigger 2929er bearing size
    Can anyone confirm the bearing size on the seatstys of a 2013 Trigger 29er 2? I measure the 10x20x7, but I can't pull the without a snap ring pliers. So I'm using calipers on the ID, OD and calculating the width...measuring 14.66mm for the two bearing at each pivot. The 4 bearings on the 15mm axles are 15x24x5 per the manual.
    Anybody have a definitive size?
    Thanks,
    Jason
    My Leatherman had small enough tips on pliers to get into and hold onto the snap rings without issue. So removing them was easy. The bearings are pressed in/out. I found a 3/4" socket, a 2" 1/4-20 bolt with a washer on the back of the socket and a washer/nut on the other side of the bearings pulled them out nicely.
    Bearings measure 10x19x5....I probably would have realized that if I had searched for a 10x20x7 and came up empty. At any rate, my bearings aren't bad, but I'll order a set in so they're on hand....along with a set of 15x24x5 for the linkages.
    Hope this helps someone. I couldn't find this information anywhere I looked. My LBS didn't know. Google wasn't helpful. MTBR didn't provide it until now either!
    Cheers,
    Jason
  1. XT rear hub bearing size?
    By Dr.Mushy in forum Wheels and Tires
    Last Post: 03-01-2012, 03:11 PM
  2. Hope BB bearing size
    By banksd1983 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2011, 08:27 PM
  3. Bearing Size for 07 5.5
    By gottjr in forum Intense
    Last Post: 01-01-2011, 07:47 AM
  4. Replies: 7
    Last Post: 12-30-2010, 01:50 PM
