Results 1 to 2 of 2
    Reputation: lowpsihighspeed's Avatar
    May 2010
    Tore a small hole in Furious Fred
    Was running my Freds tubless using DT's conversion kit and hit something sharp, tore a small less than 1/4 inch hold right in the middle of the tread. Any insight on how to fix this to conitinue running tubless? Thinking I will go back to Stan's liquid but keep the DT rim strip because the are mounted on the Ultimates DT wheelset.
    Also I have my UST Furious Freds from my last years Scalpel and have never used them. Would they work on the DT carbon rim?
    Genuine Innovations makes a plug kit. Otherwise, I've had some success with using an inner tube patch kit. You'll need to use sealant to fully seal. If it's a race rig, however, you might consider just replacing the tire for peace of mind.
