FAT BIKES
WINTER APPAREL
TRAINERS
Results 1 to 7 of 7
    Aug 2014
    Tools for Replacing Chain Rings on Trigger Carbon Team 27.5 Hollowgram Si Crank
    Dear all,
    what tools do i need (product codes) to dismantle my Hollowgram crank on the trigger. Check photo
    Tools for Replacing Chain Rings on Trigger Carbon Team 27.5 Hollowgram Si Crank-20150926_181523.jpg
    Never trust a fart
    Reputation: frdfandc's Avatar
    10mm allen wrench to remove crank fixing bolt. The the following tools to pull the crank arm off the spindle and an 8 mm allen for the extractor.
    Cannondale Hollowgram Crank Removal 2 Piece Extraction Tool - KT013/
    Aug 2014
    Quote Originally Posted by frdfandc View Post
    thanks
    Formerly of Kent
    Reputation: Le Duke's Avatar
    You also might want the lockring removal/installation tool, if you plan on removing the spider from the crank arm.
    Death from Below.
    RLTW!
    Oct 2013
    You don't need to pull the cranks off to swap the chainring though. Unless you are taking the spider off to do a direct mount. You can leave the cranks on and just take the chainrong bolts out and take the ring off...
    Aug 2014
    Quote Originally Posted by Le Duke View Post
    Part no please
    Formerly of Kent
    Death from Below.
    RLTW!
  1. ?'s about replacing crank + bb, 8spd to 10, and tools needed
    By ForrestJones in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2015, 02:13 PM
  2. Help removing Hollowgram Si crank from F29 Team
    By the_marsbar in forum Cannondale
    Last Post: 09-01-2014, 02:05 PM
  3. replacing chain/cog/rings
    By shekky in forum General Discussion
    Last Post: 05-05-2012, 01:53 AM
  4. replacing chain/cog/rings
    By shekky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2012, 08:05 PM
  5. Replacing Sram 2X10 chain rings
    By BacDoc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-19-2012, 07:05 PM
Follow MTBR on Facebook
