Results 1 to 40 of 40
    Icebiker
    Reputation: Bugeye's Avatar
    For those who've sent their DYAD RT2 back to Fox...question
    I posted this also in the Shock forum, but doing so here to ask fellow Trigger 29er owners. My 1 year old Fox DYAD was having the problems outlined in the following threads:
    fox DYAD RT2 problem!!!!!
    Fox dyad rt2 problems
    So after trying the various tips recommended in the first thread with no luck, I sent it in to Fox. I've re-installed it, and the "gap" issue is gone, however the initial shock stroke (in either long or short travel modes) feels notchy. As if the shock shaft encounters some resistance when your first push down on the bike.
    Once the shock has gotten past that initial "notch", the rest of the travel (e.g. while riding) feels fine. I don't recall having this when the shock was new, but then again I wasn't focusing on it at the time.
    Do any of you Trigger 29er owners have this "notch-in-initial-shock- stroke" issue and is it normal?
    If not, I may send it back to Fox since the recent repair should still be covered.
    Reputation: Morgs010's Avatar
    Hi Bugeye
    Mine is being looked at by Mojo who are the Fox people in the uk. When returned I will let you know how it feels.
    Had a very interesting conversation with a technician at mojo here in the UK. Basically he bench tested my shock and checked for leaked etc. Couldn't find a problem. Also he said that the piston is now going in all the way. He has replaced the bushings etc that were worn (which could have caused the creaking noises). I am waiting to put it on to see if it is fine.
    He mentioned that all Dyads are not fully serviceable and that they can rebuild anything in the shock and doesn't understand where the myth has come from about some seals not being serviceable. He also mentioned that so ermines the piston just doesn't go all the way in on some shocks even after a total rebuild and providing the sag is correct and it bench tests ok then there is not too much to worry about.
    Reputation: chick0's Avatar
    Contact Fox and get it sent back, the shock should not be notchy at all at any stage in the travel.
    I sent my Dyad to Mojo UK in Jan this year for a service and when it was returned it was making a knocking sound as it rebounded, i sent it back to them and they replaced the whole unit under warranty. So it is not unheard of that they are returned not functioning correctly after being serviced..
    Chick0, mine is back tomorrow so I will check it out. Interestingly Mojo said they have now in stock replacement shocks from Fox should they need them. One can only think the only reason they would need them was if they can't be repaired and they had problems in the past. This is of course only speculation.
    Icebiker
    Thanks guys, I'm going to call Fox tomorrow. Will report back with the outcome.
    Here is a quick video of the knocking sound the shock was making after it was returned from its first service.
    I will add that the Fox service centre Mojo in the UK pick up and replaced the whole shock in super fast time (48 hours).
    For some reason the in-bedded video is on its side, to see it the correct way click the link below
    https://www.youtube.com/watch?v=4gnaW7QWTx8
    Icebiker
    Quote Originally Posted by Bugeye View Post
    Spoke to Fox today. Fox agreed notchy isn't normal, but suggested the seals may be a tad dry since the shock hasn't been cycled much yet. Since trails around here have been too soggy to ride, I haven't ridden the bike yet any further than around my driveway. Once I put some real dirt miles on it, I'll recheck. The overhauled shock is under 90 day warranty, so I can always send it in for a rebuild/replace. Will keep you posted. Note: mine doesn't make the noise in chick0's vid.
    Ok, my shock is back. Pumped up with the piston firmly wedged into the cylinder. With great difficulty I put the shock back on the bike because the shock eye to eye with the piston fully retracted is less than the gap left when the linkages are fully expanded. 2 people had to push the linkages to be able to get the shock mount bolts through the wholes.
    My point is that the eye to eye distance is so incredibly tight that the piston will inevitably pull out a mm or 2 to be able to fit. Once the linkages get a bit of trail use with grit, sand, mud etc then this distance will naturally get bigger due to lack of smooth running In the linkages.
    Mine now runs smooth and noise free , but the piston is sticking out a mm or 2 because that was the only way I could get it in the gap.
    Reputation: MarinCRO's Avatar
    Jul 2013
    That's weird.
    I've sent had my Dyad serviced recently and when I had to put it back in, it was pretty much effortless.
    Quote Originally Posted by Morgs010 View Post
    Sounds strange, are all your suspension pivots lined up correctly? It might be worth stripping down and rebuilding the whole rear end of bike.
    Icebiker
    ^^^agree....Morgs, I think you have to re-look at your linkages...I installed mine super easily, no gaps, no pushing down on the bike....
    Have checked out my linkages and it seems that the only thing stopping the linkages from folding back on themselves and hitting the seat tube is this stopper coming from the rear stay and hitting the bottom bracket. Mine is touching with the piston sticking out maybe 2mm. When I put the shock back on I couldn't increase the eye to eye distance because it seemed this stopper was stopping it.
    This is what it looks like now, but off the frame there is no piston sticking out.
    Yep but when unweighted the dyad doesn't show piston. I know this because it was fine when off the bike. The eye to eye is very tight on my bike which causes the piston to pop out
    Jul 2013
    So, you're saying that if you were to let all the air from the negative Dyad' chamber, it would still look like this?
    If so, it's possible that the bike is not built properly. Check the rear pivots and try to find a cause.
    Interestingly when all the air is let out of the negative the piston is all the way in. I run the shock 290, 245. As soon as I get to around 200 on the negative, the piston just shows it's head. Once the shock is taken off the bike it looks fine which is what the Fox service guys based their assessment on.
    Jul 2013
    It's possible that you're losing a lot more pressure in the positive compared to the negative chamber after removing the pump, so the actual positive air pressure is lower than you believe it is, so "proper" negative pressure causes the piston to extend a bit.
    Try pumping the positive about 60PSI more than the chart shows as that's about as much as you lose after removing the pump.
    Quote Originally Posted by Marin (CRO) View Post
    Yes, this a common problem due the high pressures, air escapes with more force. I found that using the Scott high pressure shock pump helps this a bit, as it has a twin release mechanism.
    Have decided to use it over Easter and see what happens. Checked the pressures today. Positive 20 psi down which equates to the usual Cannondale pump connection loss, however negative wax 50psi down from usual.
    I have the fault registered with fox even though they say they couldn't find anything wrong so if problem continues I will insist on them having another's look or new shock
    Icebiker
    So I took the bike/rebuilt shock for its first ride today. About 7 miles before I switched to my hardtail for the remainder of the ride. Shock is now making a "clunk" or knocking noise (no gap though). Going to call Fox again.
    Update on my Dyad. Some how, the piston seems to have moved back to its proper position ie not sticking out. This happened after 2 fairly hard rides. Shock pressures seem fine too. The only difference seems to be the shock feels softer and goes through travel more easily. I have increased pressures which are still way below Fox recommendations and it is fine. Fingers crossed
    Have been using my trigger for 3-4 rides now. Still working fine with the piston finding the correct position. I am now fairly certain that it was the linkages that wS stopping the piston going all the way in. It was incredibly tight re-fitting the shock as previously mentioned and as such the piston came out. Once I had ridden the bike once I gave it a super clean and slight lube around the linkages and it settled down with the piston going back in. I reckon there was some muck stopping the smooth operation of the linkages which may have equated to the tapping noise the shock was making when the piston was sticking out pre service.
    I have finally got to the bottom of the mystery as to why the piston was staying stuck out and why it has suddenly started sitting perfectly again. Basically the stopper that seemed to be stopping the suspension fully extending (photographed earlier in this post) has now fallen off allowing the piston to retract. Clearly it wasn't fitted correctly. I will now need to get a replacement.
    See photo
    According to my LBS, this is incorrect. The air you hear escaping is just the air that is left in the pump. As you unscrew the pump, the shraeder valve closes, sealing and not allowing any air out of the shock then as you continue unscrewing the pump the air is eventually released from the pump. If you start trying to add air to compensate for what you think your losing, you won't know where your really at. The reason the pressures are lower when you re-check is that when you screw the pump back on the air in the shock escapes back into the pump.
    I have a Jekyll and have gone thru all this before. (ie shaft sticking out) The other thing I found helps with getting the right pressures is makeing sure you screw the pump on tight every time you pump it up. Not sure why but it makes a difference.
    Anytime the the ratio of + to - pressure is high on the Negative side, the shaft will want to extend.
    Peace.
    Reputation: radiomir79's Avatar
    hi guys,
    since the dyad is surrounded by lots of myths and mystery, here are some facts,
    I collected over the last 3 years riding and servicing my dyad on the claymore.
    I am a hobby mechanic, I do service my forks and shocks for more than 20 years now, but I am not related to fox, nor did I use the correct technique to fix my shock. (but if it works, than I think I didn't mess it up totally)
    here are some facts about the mystery DYAD thing:
    1. the shock is fully serviceable, it just requires some special tools and quite some routine. Do not attempt to service it unless you have the correct tools and experience. (A LOT OF EXPERIENCE)... the chances are, you will not be able even to open it!
    2. fox does not sell the seal kit for the dyad. I was able to get 5 sets from ebay over 2 years ago from a guy from the US. ...this was the last time I saw somebody offering the full set of bushings and seals for the dyad.
    3. you need some special tools for the job: I did ask my local shop to machine a bleed nipple that attaches to the big screw on the back of the shock body to drain all air out of the system. I may be totally wrong but it seemed to be the only way to drain air from the system. It worked fine. (2 hours of very oily experience)
    4. most of the fox shops use a vacuum pump to bleed the unit. (from what I was told)
    5. the piston MUST be 100% flush with the body. if it sticks out, you have:
    A: seal leak - main piston seal leaks oil into the AIR chamber, pushing the piston out.
    B: need for a reset of the unit (in some cases the pistons separating air and oil chambers may move a bit inside causing the main piston to stick out of the body) a simple reset may solve the problem. (reset - release all air in positive chamber, let the piston fully extend from the body, release the negative chamber, AGAIN press the positive chamber air valve. in extended position pump the positive chamber to required pressure, the piston will move back to the body. than set up the negative chamber. repeat if the piston still sticks out. when you give it 2-3 goes., and the piston is still not able to return fully to the body, you than have a failure. the shock is not okay, even if it feels working good! NEVER DO THE RESET WITH UNIT MOUNTED IN THE FRAME!!! the weight of the bike will not allow to reset properly!!!)
    6. Knocking sound: yes it is NORMAL that the unit gives this knock - knock sound when pressing the seat in the elevate mode. this is caused by the shim stack located under the top cap. the shim stack is a bit loose (dont know how to describe it)... it appears to be a bit loose. remember: the knock sound is acceptable only to a certain level, in most cases you will not hear it in flow mode at all! if you do, your shock needs service!!!
    7. if you see extensive oil leak when unscrewing the pump ( i am not speaking of 2-3 drops of lubrication BLUE fluid from the air valves, but a small stream - you WILL KNOW when you have one) this means you have a seal leaking.
    8. dry seals: there is NO CHANCE for dry seals inside of the dyad! upper part is fully filled with oil, the air chamber is filled with the blue lubrication fluid. EVERY TIME you bottom out the shock, it is lubricated from both sides and the same is happening in the spool valve! fully submerged in oil and lubrication fluid. unless it was assembled by a monkey, it should not be dry at all!
    9. MAKE SURE TO SCREW THE PUMP FULLY IN when setting the pressure! it is not written in the fox user manual, but there are 2 air valves behind each other in the long tube connecting the chambers! you will notice a 2x shhhh sound when screwing the air pump in.
    if you dont, you will be inflating only the first chamber. Also, the sound you hear when you detach the pump IS 90% the air from the pump itself! if you wanna be 100% sure you are spot on with the air pressure, get a RESET air pump adapter. (german company, google it!)
    10. GET SOME HEAVY DUTY BUSHINGS (huber in germany or TF tuned in UK) the original bushings are crap! they don't last, have way too much stiction, and CREAK when ridden in mud or dry conditions.
    11. since most of the jekyll shocks (old models) have a too slow rebound setting, you may need to revalve the shock. (ebay would be a nice source to get shims for fox)
    To my surprise, fox uses thick damping oil in the dyad, DONT try to change the oil to a lighter one!!! - learned it the hard way - if you change the oil to a w5 or even w2.5, you will eventually loose a lot of compression damping!!! you need to change the shim stack!
    unless you wanna bottom out the shock on drops and jumps and loose the infinite travel feel...
    12. your dyad WILL fail! yes! sooner or later it WILL require service. Peter Denk (designer of the cannondale bikes) once said that pull shocks will last longer. Unfortunately this is not the true. In theory, the piston sure is hidden in the body all the time, straighten itself, not putting pressure on the inner seal and piston bushing, BUT it also works with very high pressures! the working pressures of the dyad are 2, maybe 3 times higher than the regular push shocks.. Unfortunately the bushings holding the seals and the seals alone can not last as long as in regular shocks. NO WAY! this is how it is designed!
    writing this, I am not trying to encourage you to rebuild your shock, I am not explaining the proper way to do it, Im just stating some facts that may help some of you to have a better idea how the unit works. The dyad is a unique piece of technology, but I think it may be a bit over-engineered. I love my claymore as much as I love the function of the dyad., but for sure the pull shock technology needs some time. We will see how long cannondale will be going this way (and if other companies will follow)
    please excuse my English, Im not a native speaker.
    thx and rock on!
    r.
    Icebiker
    Thanks radio...very insightful. Even if I won't be servicing it myself, it's good to know a bit more about how these work.
    As for my clunking/notchy issue..UPDATE: After sending it back to Fox a 2nd time, the shock has come back and has no more knocking sound. They also installed some newer-style black bushings (even though the silver metal ones they installed at the first rebuild were essentially new) . Kudos to Fox for a very quick turnaround, during Sea Otter week no less).
    However, i did continue to observe the "notchy" feel in the initial stroke. So, I started experimenting. I eventually found that the notchy feel disappeared when I removed rear derailleur tension (e.g. I pushed the cage forward and engaged the lock button, letting the chain go slack). Smooth as silk in this mode. So, I think the notchiness is related to chain tension. I can live with that. My concern was that the shock was bad, but it turns out it's all good now.
    OMZ
    OMZ is offline
    Yes, type 2 clutch derailleurs cause that "notchy" feel in the initial stroke. I have found this is worse with Sram clutched derailleurs than it is with Shimano ones. Do you have a 2013 Trigger 2 with the Sram X9 type 2 rear der?
    Just roll with it. There's nothing wrong...
    I have found that adjusting the clutch on the mech (making it slightly looser) stops this clank.
    Icebiker
    Quote Originally Posted by OMZ View Post
    Yep, that's the one. I'm ok with it knowing that it's not the shock. Interestingly I had observed early on in the bike's life that the rear cluster made a fair amount of clunking when backpedaling in the bike stand, suspect that too is related to the clutch. Neither are a concern for me...I'll take the clutch's ability to prevent chain suck over any noise/notchiness any day....but me thinks when this drivetrain wears out I may spring for an upgraded rear mech....or maybe even 1X11
    See photo
    Good lord, that isnt a stopper. Its where the end of the housing for a front derailleur stops. Scalpels have it too. It servs no purpose on a 1x bike. You or your bike shop should have removed it for you since you have no front derailleur.
    my church is the woods
    Reputation: moonraker's Avatar
    Quote Originally Posted by SmilMick View Post
    Doesn't look like a housing stop. And why would the housing stop be located on the swingarm, where it moves up and down; which would be then moving the front derailleur?
    Quote Originally Posted by moonraker View Post
    It is a housing stop. Front derailleur on Scalpel, Trigger and Jekyll actually mount to the swingarm.
    I realize this is an old thread but.....
    morgs...that "stopper" is a small disc that resides in that cable stop to mount the front derailleur housing and allow it to swivel some with swingarm movement. It typically comes from the factory with a piece of tape over it (bikes with no FD, 1x10, 1x11) to hold the disc in the mount so it doesn't come out. Looks like the tape came off and the disc was free to come out.
  1. Back on a YS, SS setup question
    By Blatant in forum Canfield
    Last Post: 11-17-2013, 06:57 PM
  2. Set up Question for DYAD shock owners
    By Bugeye in forum Cannondale
    Last Post: 05-14-2013, 07:16 PM
  3. Jekyll 3 DYAD question..
    By jjjj in forum Cannondale
    Last Post: 08-30-2012, 03:44 PM
  4. New Back rim question
    By fuelinjection23 in forum Downhill - Freeride
    Last Post: 02-22-2012, 03:52 PM
  5. Set back seatpost question
    By Doughnut Spaghetti in forum 29er Bikes
    Last Post: 08-27-2011, 07:44 AM
