Results 1 to 8 of 8
    Reputation: mtbj's Avatar
    Is there a special direct mount derailleur for Cannondale Flash???
    I ordered a direct mount XX front derailleur for my team Flash. The holes are too far apart though. Are there diffrent direct mount hole paterns?
    29er S3
    26er S2
    The one I ordered says S1 on the back. I dident know there was so many options.
    Quote Originally Posted by mtbj
    Yep. The direct mount FDs are quite complicated. Make sure you order the one specifically for your front ring too. If you didn't, it should still work though.
    26 Flash w/42T: order Direct Mount S2 42 Bottom Pull
    26 Flash w/39T: order Direct Mount S2 39 Bottom Pull
    29 Flash w/42T: order Direct Mount S3 42 Bottom Pull
    29 Flash w/39T: order Direct Mount S3 39 Bottom Pull
    Of course this is all assuming you are running 2x10 (which is required to be able to use the XX FD) and the XX chainrings (not required)
    YB1
    YB1 is offline
    Quote Originally Posted by trauma-md
    I am planning on running a 44/30 front chainring combo on my new Carbon Flash 29'er on the standard Hollowgram four arm spider outer and middle position with the inner left empty for now. You're making me think it may not work with the stock FD. Maybe I should get the triple one because I'd like to have the option of throwing the inner 22 tooth on even though I probably never will do that...
    Emory Kalahari Kruiser
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    2011 models are all S3
    Flash and Scalpel
    May 2005
    lots of 'em
    for the record there are something like 42 different XX FD's...pull, hole spacing, etc...
    great era to be an IBD!
    Shimano Front direct mount option on Flash
    I built one up last month and Cannondale makes kit# kp123 that will convert a shimano E-type front derailleur to mount to the Flash carbon frame.
