Results 1 to 2 of 2
    Tech Help Needed - Headshok Installation
    I need some help from the Cannondale experts.
    I bought a used Cannondale frame and fork and the seller removed the fork for shipping. It seems I need to install the fork by pressing the bottom headset bearing into the frame (with everything together, of course). Is there a trick to this? What tools do I use?
    Thanks for your help.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    They just press in with a friction fit. This includes both the bearing cups and the actual bearings. I just use a rubber mallet and slowly tap it in evenly until it is seated. Then you can do the same thing with the bearings.
