    Jun 2010
    Swapping spider chainrings on sisl2 crankset
    Hi,
    I'm planning to change a spider chainring on newly arrived super six evo from 53/39 to 50/34. Crankset sisl2. I will be doing this for the first time and therefore need an advise from experienced guys.
    Do I need to disassemble compete crankset, or can I just remove a drive side crank with the spider?
    Also, do I need a special cannondale tool to remove a crank from spindle?
    Thanks.
    Reputation: StumpyElite2010's Avatar
    I went through the same thing a few months ago.
    Drive side only...
    You will need the 2 piece extraction too KY013 - Cannondale Hollowgram Crank Removal 2 Piece Extraction Tool - KT013/ - CannondaleExperts.com
    As well as the Spider Lockring Removal Tool - KT012 - Cannondale Hollowgram Spider Lockring Removal Tool - KT012/ - CannondaleExperts.com
    While you at it, get the spidering... Cannondale SpideRing Road Chainring Compact 50/34T - KP245 - CannondaleExperts.com
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Jun 2010
    thank you,
    this should be logic, as both crank arms dismount separetely...
    I have already ordered those tools, so waiting them to arrive )) and the smaller spidering came with the bike.
    did you put a loctite 242 on a new spider as shown in the manual?
    Jun 2010
    seems like I have a problem finding Loctite 242 and got 243 instead. Is is a big deal if I'll use loctite 243 eventhough the manual says to use 242?
  1. Swapping Shimano Crankset on a Trek Fuel EX
    By maragzner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2014, 07:07 AM
  2. Drivetrain Upgrade Using Northshore Spider for XX1 Chainrings
    By Jrsandiego in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2013, 09:54 PM
  3. swapping chainrings on XTR trial crank
    By shanem in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2012, 06:58 AM
  4. SS chainrings for XT-770 crankset
    By Westrider7 in forum Singlespeed
    Last Post: 12-09-2011, 06:39 PM
  5. Truvative Chainrings 2x9 for Hollowgram spider
    By dvizzoca in forum Cannondale
    Last Post: 05-11-2011, 12:39 PM
