I have a 2004 Scalpel 2000 with a carbon Lefty DLR. I was looking for guidelines for suspensions setup. What air pressure to run for the Fox Float Pro-pedal and how many mm of sag? What pressure for the Lefty? I weigh 152-155 and will be racing mostly. Also can the lefty oil weight be changed, or is it standard and you adjust the air, rebound, only?
Thanks for the help, cause I think suspension setup is extremely important.
