Results 1 to 2 of 2
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    Suspension set up on a 2005 Team Scalpel
    Does anybody know the proper air pressure for both the Lefty and rear Dt-Swiss shock for a 160 # (with gear) rider on a medium 2005 team replica Scalpel?
    Also what rebound and compression settings are people using?
    Thx
    Reputation: keetowah's Avatar
    Mar 2005
    Here is a link to DT's manuals http://www.dtswiss.com/index.asp?fus...elchairrshocks
    Not sure if it tells you in there or not. I know the RP3 manual has recommendations of sag, but check the manual see what it recommends. Here is a scan of the manual that came with mine:
    You can't test courage cautiously.
    -Annie Dillard
