Results 1 to 10 of 10
    Aug 2013
    Super v1000 replacement DD50 Headshoks
    I have a 96 super v 1000 with DD50 headshocks. The shocks only lock out and no longer have any spring to them. Does anyone know what type of Headshoks will fit this bike? They no longer make the DD50.
    Feb 2005
    Any Headshock or Lefty will fit.
    Only caveat is this.
    If your headset cups are wider than the headtube, and have pinch bolts to hold the bearings in place? You'll need a modern press in SI Headset, which runs about $60 IIRC....
    Happy hunting!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    o<o NYC pebble jumper!
    Reputation: skene's Avatar
    May 2013
    I wouldn't happen to know really, but I'm gonna go out on a whim and ask if this headshok requires you to put air in it and fill through the bottom using a suspension pump?
    Feb 2005
    Quote Originally Posted by skene View Post
    Good thought, but that fork is elastomer sprung, not air, and the elastomer has rotted to nothing.....
    - FrostyStruthers
    Aug 2013
    Ive called bike shops and serched the web for a week and I finally have a straight forward answer! THANK YOU!!
    Aug 2013
    The Headshok does not have an airstem under the forks.
    Aug 2013
    I wonder if a new elastomer would do the trick, the trouble would be finding one and installing it.
    Feb 2005
    These guys *might" have what you need....
    suspensionforkparts - Home
    - FrostyStruthers
    Link above not working for me so I can't tell what it says, but I got a new spring/elastomer kit for my 94 delta V. This should work with your fork, but unless you have the right tool it's really difficult to get the old spring out.
    Spring Fatty 50 new - Dr. Cannondale
    Aug 2013
    above link - suspensionforkparts - Home
    Thanks! I haven't opened up the forks yet but I will take a look inside and see what Im up against.
  1. Bought a 2008 F4, with knackered headshoks
    By mawwam in forum Cannondale
    Last Post: 06-13-2013, 09:58 AM
  2. DD50 cartridge teardown
    By Dale1K in forum Cannondale
    Last Post: 04-08-2012, 01:15 PM
  3. Ringle Super Eight bearing replacement
    By Retro Dude in forum Vintage, Retro, Classic
    Last Post: 06-20-2011, 04:19 PM
  4. Pedal Thread Size On A '94 Super V1000
    By cda 455 in forum Cannondale
    Last Post: 04-12-2011, 12:58 AM
  5. Help Finding Stem For '94-'95 Super V1000
    Last Post: 02-17-2011, 01:04 PM
