Results 1 to 8 of 8
    Super V bottom bracket size?
    Can anyone confirm that the bottom bracket size is 68x113?
    I'm having trouble getting a 68x113 octalink bb to fit - it seems to be a few mm too big.
    Feb 2005
    68 is the shell width, so that much is correct.
    The spindle length is determined by the cranks used, and we don't have that info currently.
    Also, V1 or V2 splined? Don't mess up your cranks by mixing the two.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I'm pretty sure they are v2 splined as they are Deore mtb cranks.
    Feb 2005
    Yes, they are V2, and really? 113 is too long?
    What's making you think this?
    There's 109.5 in the V1, but that's usually reserved for road cranks, and obviously won't work in this case.
    - FrostyStruthers
    The steel retainer doesn't quite fit into the bottom bracket shell, its about 1-2mm out, it may need a clean or something as its not been used in quite some time ( the question on here was more of a sanity check that I had the right size bb )
    Feb 2005
    Steel retainer?
    Do you mean the non drive side cup?
    They generally stick out a little bit once fully snugged, if that was what you're referring to...
    - FrostyStruthers
    Mar 2014
    Super V bottom bracket upgrade
    Quote Originally Posted by MendonCycleSmith View Post
    Steel retainer?
    I would like to upgrade the bottom bracket and crank on my 2000 Super V 700 SX. Will the outboard bearing Shimano bottom bracket and XT MT 780 crankset work? Thanks.
    Feb 2005
    68 mm BB shell is pretty normal stuff, I can't see any reason you can't, no.
    - FrostyStruthers
  1. 98 FSR Bottom Bracket Size?
    By Dads Taxi in forum Specialized
    Last Post: 10-11-2012, 03:14 PM
  2. Bottom Bracket size
    By Markleo in forum Beginner's Corner
    Last Post: 09-25-2012, 03:10 PM
  3. Bottom Bracket Size help please
    By njl1992 in forum Frame Building
    Last Post: 03-21-2012, 11:54 AM
  4. Bottom Bracket Size
    By marxcamaro in forum GT
    Last Post: 01-05-2011, 06:04 PM
