Here's a guide to removing, dissassembling and reassembling a Cannondale Super Fatty M Headshok -apologies for the length. I'm posting this so other people can see what I did to service my fork. I did not have a lot of money; my Headshok was bottoming out constantly and felt too weak on compression. Add to that my woes of getting dirt into the needle bearings and a torn boot, and I knew I had to do some work to it. I could, of course, have sent it off to Cannondale or gone to my local bike store (big Cannondale dealer) to get if fixed and rebuilt professionally..... but factoring in a new firm spring kit, boot, labour, etc, I think I was looking at a conservative $150 minimum.
Since I already had a spare 1 1/8 headset and stem, and Manitou SX-R forks (year 2000 model) can be bought on Ebay for around $90 (add in another $40 for headset reducer cups) including all shipping, if I was going to spend around $150, I would have spent it on the latter option. In short, money talks for me and my experience with Cannondales has taught me to prefer non-proprietary bike stuff. Oh yes, I know Manitou SX-Rs aren't exactly modern technology nor the best suspension, but neither is the Headshok Super Fatty M -and since I have an SX-R on my hardtail, I knew what the fork was like -its tunability, reliability and performance were all more than adequate for me.
THE GOOD STUFF
It can be done. I did all work by myself with no help. It can be a one person job. It's not half as bad as people will lead you to believe, and the design of the fork holds no terrible secrets -conceptually it's actually pretty simple! A cautionary note though: I found the job to be pernickety in the sense you had to do some stuff in the right order, and it makes a difference if you do. All I can say is that the order I've listed is the order I found that worked for me, and usually there's a method in the madness for a reason.
Total cost for me to regrease, put a boot on, install new needle bearings and firm ride springkit and purchase any tools I needed: about $70. It took me about 8-10 hours in total to disassemble, reassemble, disassemble and reassemble again (includes thorough degreasing and cleaning). Admittedly, I do have some tools already, but everything else I needed I use in the general maintenance of bikes and is not Cannondale specific (e.g. hammer, Slick Honey grease, Pedros degreaser, etc).
CAVEATS
So this leads me to caveat number 1: basically I had nothing to lose. If I screwed up this fork or couldn't get if back together, it didn't really matter, I'd just go ebaying and get a set of adaptor cups and a used fork (also keep in mind I believe when you strip a Headshok, Cannondale may consider any warrantees null and void). My primary objective was to disassemble the fork and put it back together. If I could do this, I'd then invest in the necessary Cannondale parts and fit them myself. I had nothing to lose but time here.
Onto caveat number 2. Since I do not have access to top secret classified Cannondale documents regarding servicing/assembly of Headshoks, I am not privvy to torque specs or the like. This means that I put this fork back together the best way I could (Cannondale diagrams notwithstanding) using at best some guesswork and "common sense" ("common sense" here is very subjective I know. Let me reveal here I'm not a professional bike mechanic, nor am I a qualified mechanic in any area. What I have done is strip various car/motorcycle engines down and put them back together -working mind you!!!! -and my wife believes I have a natural aptitude for mechanics. Then again, she says I'm really good looking too ;^). I consider myself to be confident at mechanics..... confident in knowing when I'm out of my depth). The point here is that I'm just posting what I did -I am by no means suggesting this is the proper or appropriate way to safely reassemble a Headshok. So here you have it, caveat number 2: You mess with your Headshok at your own risk and this posting does not constitute in any way any endorsed ways of properly servicing or assembling or reassembling Headshoks. I am also not responsible for your costs or damages incurred, personal injuries, first born child, blah blah blah. It's all your responsibility and I can't vouch for the accuracy of this post or be responsible for any mistakes contained within.
Finally caveat number 3: I did my work on a Super Fatty M. I have no idea about any other Headshok models, they may be totally different as far as I know. The Super Fatty M is an 80mm travel spring/elastomer model with variable compression via an allen key adjustment after removing the top cap. It came as standard on my 2001 model year Jekyll.
RESOURCES
OK, before I started this, I combed the internet looking for help. I googled, I yahooed, I did everything I could to search for any variation of the words "Cannondale Headshok Headshock assembly disassembly installation removal" etc. Let me tell you: there isn't much out there. And what there is, is hardly encouraging. Certainly Cannondale provides no technical help in the sense of stripping down a Headshok -just rather weak technical diagrams and advice such as "service at an authorized dealer every 40 hours of use". Hmmmm. Anyway, here are some helpful links I found:
http://www.fastglass.net/bike/headshok/repair.html (also has Cannondale technical diagrams in the archive. This was the site that helped me the most -not least because of the clear directions but also great photos. On the downside -and rather worrying for anyone reading it -it does not include reassembly instructions, nor the disassembly of the bearings and races).
http://www.bikeparts.com (has some Cannondale Headshok parts as well as proprietary tools such as the castlenut tool ~$35)
http://www.cannondale.com/bikes/tech/headshok.html (Cannondale's own documents for Headshoks)
http://www.cyclingforums.com/showthread.php?t=21400 (thread on Headshok disassembly)
http://groups.google.com/group/rec....adshok+assembly&rnum=1&hl=en#84be9a1ca8d0cd7a (another thread on Headshok disassembly)
Some of the common themes I found in the message boards are:
(i) don't take a Headshok apart
(ii) if you do, don't ever, ever, ever take apart the needle bearings and races.
Ooops, too late. I've always been a bit pigheaded anyway -and like I said, I had nothing to lose.
TOOLS
old inner tube (700x23 was the best size I found)
scissors
small flat bladed screwdriver
zip ties
degreaser
Slick Honey grease (does not degrade elastomer stuff)
WD-40 (helped degrease parts)
Threadlok (missing from photo)
11mm open ended wrench
Green Park SPA1 pin spanner (had to buy this from my local bike store $9)
hammer
block of wood
allen keys
old front axle
vice and workbench (well lit!)
home fashioned castlenut tool out of old door hinge (used a hacksaw and file, as well as a hammer and vice to knock this into shape).
electrical tape
rags (missing from photo)
paper towels (missing from photo)
plastic ziplock bags (missing from photo)
outer race holding tool (fancy name for an approximately 15cm length of 700x23 inner tube with valve very close to one end, zip tied at both ends)
THE GOOD STUFF
CAVEATS
RESOURCES
TOOLS
scissors
zip ties
degreaser
hammer
block of wood
allen keys
old front axle
electrical tape
