Results 1 to 7 of 7
    Stubby-legged
    Stubby riders and the Rize
    I am 5'3.5 (if I stretch). Does that mean I need to ride a Petite womans rize?
    I would prefer a rz140 (or better yet, a Moto), but like all other bike companys, Cannondale thinks all men are 6 ft tall.
    Feb 2010
    Quote Originally Posted by 1spd1way
    Have you tried a small yet?
    Stubby-legged
    not yet
    LBS doesn't stock a lot of fs mountain bikes (a ton of high end road bikes !)
    I'm going to see if the rep can bring in a small when he does his "rounds". We'll see.
    Reputation: sanjuro's Avatar
    Sep 2004
    Cannondale is slightly larger, but keep in mind that with fs bikes, there has to be some height allowance for suspension designs.
    You can't build a 6 inch travel bike without putting the 6 inches of travel someplace in the geometry.
    5'3" is the bottom end of the size small. Standover will always be an issue but I think you can get a good reach to the bars.
    P.S. I sold a 1FG to a 5'2" guy.
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Well, then they should be able to measure you correctly to determine the correct size for you.
    Simple as that.....
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Reputation: jdr01930's Avatar
    I was really disappointed at the higher standover height of the Rize, vs my good old Prophet. For that reason alone, I keep the prophet and will not be getting a rize.
    You might consider a used Prophet - the Delta V style frame is more "shorty" complient.
    You might not pick up on that by looking at the specs, it's all in the angles and curves of the top tube.
    '15 Cannondale Trigger 27.5 Carbon 2
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    '08 F6 Lefty (son's)
    Feb 2007
    My wife is 5'4" and has an inseam of 31". She rides a size small Rize, and she loves it. Check your inseam and see if if you have long enough legs. The effective standover of the Rize and RZ140 is 29.8 inches. Good luck!
    As for the Super V standover, we came from riding Super Vs and loved how much room it had, but the climbing and weight left my wife (120 lbs) out of breath. We decided it was time to upgrade.
