Results 1 to 10 of 10
    Reputation: surf418's Avatar
    stock stem on a medium Rush
    Hi there,
    What is the size of stock stem that come with a medium Rush ? Bought mine used and it got a 120mm, 20 degrees.
    Also, is there any other brand of stem that is compatible with the lefty and FSA bar ?
    anyone ?
    Reputation: ccaddy's Avatar
    Woodman is one of the few who make stems for the Lefty .
    I need one of theirs but they are supposivly in the middle of getting
    a production run to build more as they are out of stock
    I tried to contact them a couple of times but I do not get any replies
    Thanks CCaddy,
    I've never heard of Woodman. I'll look forward to find them, if i find something i'll let you know
    ...soon to be sith lord..
    Reputation: obi_twan_kenobe's Avatar
    Dec 2005
    Hey surf. There are a couple of companies that make Lefty compatible stems, but the problem is that they weigh more and cost more than C'dale stems. Your best bet would be to go to your lbs and get them to size you a stem and get one from C'dale. Heck, they may even have some laying around from swaps.
    There is a fine line between control and catastrophe
    Northeast Tennessee Mountain Bike Association
    mad aussie
    Reputation: Flying Wombat's Avatar
    My medium Rush 600 came with a 5 degree 100mm stem for what its worth. Stem length depends on your torso length and riding style.
    I would go with the stock stem, if you can find a LBS who has the suitcase of all the stem sizes to try out that would be ideal.
    Kevin
    Thanks Flying Wombat. My medium has a 20 degree 120mm and its too high or too low depend on the side i put it. I'll try to find a 5degree 120mm. LBS doesnt have much choice..
    Hard to find dimension stem here .
    Finnally i ordered a Cdale 5degree, 120mm. I will install it and ride it tonight. I've checked with Woodman and they were available at the very same price of Cdale's (64$) in Montreal.
