    Reputation: 2therock's Avatar
    Jun 2010
    Stem Recommendation For My Cannondale?
    Hi guys,
    See my bike and specs in my signature if you are kind enough to help.
    I need to get some weight off my hands. I think I am too far over.
    It has been suggested I make the adjustment with a stem. Seat height or front to rear position does not help. They are fitted pretty good as that goes but I did experiment to see and returned them to their original positions.
    Can I get a suggested vendor and type that is not the super high dollar tech big time Bling Thing. Just a comparable to OE but higher to sit me up some.
    Mine is a Cannondale XC3 1.5. I hope I don't need the part that goes through the head.
    And how much of a degree in rise will it equal to in inches?
    Reputation: sanjuro's Avatar
    Sep 2004
    Usually, riders rarely pull out the slide rule to calculate stem angle to bar rise.
    Most stems are about 5 degrees of rise, and the next higher is 15 degrees.
    And getting the same length stem but in a higher rise will NOT bring the bars closer. Stem length is measure on a parallel line to the ground, not from bar to steerer.
    Jun 2010
    Thanks, This is why I ask because I do not know. So higher will not relieve any of the weight I am putting on the bars?
    Sep 2004
    Oh, it will be an improvement. I looked at your picture, and your bars are just above the saddle.
    Raising the bars will take pressure off your back, but you might also want a shorter stem as well.
    Hard to say over the web because you could change your handling with too drastic of a stem change.
