Results 1 to 2 of 2
    MTB'er
    Nov 2007
    SRAM XX on 2009 Scalpel
    I would like to switch my XTR Shifers and Derailleurs to SRAM XX on my 2009 Scalpel 1. Based on the specs it looks like the Front Derailleur could be a Low-clamp or High-clamp bottom pull. I have a low-clamp XTR front derailleur on it now. I have had some issues in the past with small rocks getting stuck in the XTR Low-mount derailleur and not being able to shift down to the smaller ring until I stopped and removed the small rock. Any advice on witch one to get would be appreciated.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    install an high clamp.
    Scalpel has a alu seat tube , able to reach both clamp types .
    high clamp , bottom pull XX front redailleur 31,8mm will be the right one
