Results 1 to 16 of 16
    meatheadboy
    squeaking lefty?
    Hey there,
    So I bought a new Scalpel 29er 3 a few weeks ago, I absolutely love the bike, such a fast bike.
    The only thing that is a bit annoying is that every ride I go out on, after about a mile or two i develop a squeak in the front hub. it's not break related, it almost sounds like rubber squeaking against something.
    Any thoughts? I don't want to be that guy that is always running to the shop to fix ghost issues.
    Thanks,
    John
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    Quote Originally Posted by johnhugo71 View Post
    Hey there,
    Thanks,
    John
    This issue has been mentioned on this forum numerous time....the search function is your best friend....
    Remove axle cap, take out O-ring from axle bolt, replace axle cap, done.
    Be aware of the cap being reverse threaded.
    If you don't want to remove the O-ring a few drops of oil inside that gap between axle bolt and cap will help.
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    meatheadboy
    thanks, i put in Lefty Squeky Hub and got about 1,000 things, none of which said anything about this.
    If i'm searching incorrectly please let me know.
    I appreciate the reply and will do that tonight.
    Thanks,
    John
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    I whore around on this forum all day and it's the first time I hear about this problem as well as the solution.
    Ridin' dirty!
    Mar 2013
    Thanks,
    John
    Always make sure youre spelling the words correctly. If you dont, your search wont yield proper results.
    Jan 2009
    Some great info in those threads.
    These are 6-3 year old threads. I guess you'll never see them if you don't do a search.
    I love the irony of your Sig: "Common sense isn't always that common!"LOL
    Ridin' dirty!
    [QUOTE=Thatshowiroll;10526918]Some great info in those threads.
    I love the irony of your Sig: "Common sense isn't always that common!"LOL[/QUOTE)]
    lol if you use google the mtbr threads will pop up right away too...
    Is there a good picture where this bushing is at? I have a Flash 29r carbon and have had my bike to the LBS about 3 times for this, and they keep greasing it and still there.
    A good picture of the bushing and exactly where it is would be great!
    Thanks a lot!
    I love this bike, but the squeal is almost making me think about trading it in!
    Well I just had mine to the LBS and got the little rubber o ring out.
    Got it our for a ride, and squeak is back and louder than ever and more frequent!
    Any other ideas?
    Feb 2005
    Bad bearing, rotor warped a touch and contacting the pads, that mouse you thought you finally killed last winter?
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Hey Thanks!
    So I took ti back to the LBS after searching this forum, and this time we removed the grey dust cover washer looking thing.
    Squeak is still back! Is there a better bearing I could be using, and how many bearings are there in that hub of my flash carbon 3 29r'
    Also the rotor spins fine, no touching.
    Thanks a lot guys!
    Feb 2005
    Sounds like you either need to give us more info, like how and when it does, whatever it is it does.
    Or, the shop needs to stop simply removing things and handing the bike back to you, and actually undertake a systemic approach aimed towards getting to the bottom of it....
    Two bearings, and quality isn't really at issue, any bearing should be silent, if it's not, it's simply bad, cheap or not.
    - FrostyStruthers
    Thanks Mendon,
    It sounds like crickets, and it is usually when the wheel is turning and has load on it and going at a good rate of speed.
    I should also add Im 290lbs. Which might be the real issue too. Limit is 300lb on these bikes.
    Feb 2005
    Black spokes I'm guessing?
    If so, wheel tension. You running a decently beefy rim? I would be, and a nice tight built wheel too.
    - FrostyStruthers
    Guys I wanted to update my "lefty Squeak"
    Turned out it wasn't coming from the front,, but the rear disk piston not releasing all the way!!!!! I could have swore it was coming from the front of the bike!
    Wow I'm glad this got sorted OUT!
    Now bike is back to being silky smooth. They backed the pads out, and did something with the piston.
    So my advice, have a few others listen and look at where that noise is coming from,, could be the opposite end that needs addressing.
  1. squeaking mc 3.3
    By D-Avid in forum Shocks and Suspension
    Last Post: 03-30-2013, 05:10 PM
  2. Brakes squeaking
    By CWnSWCO in forum Beginner's Corner
    Last Post: 11-24-2012, 01:15 PM
  3. Squeaking - What have I done?
    By glouden in forum General Discussion
    Last Post: 06-16-2012, 06:58 AM
  4. Squeaking Fork-What should I do?
    By AlwaysInjured in forum Shocks and Suspension
    Last Post: 04-13-2012, 05:30 AM
  5. Squeaking crankset
    By manamana in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 10:14 AM
