Results 1 to 5 of 5
    squeak from headshok on 04 F600
    I am getting a squeak as I go through the travel on my F600. can I lube it and if so with what and how do I do it? thanks
    This is exactly my problem too on my Scalpel 900 (european) Headshock Ultra DL.
    A small squeeky sound when traveling. Think it had something to do when I dipped the bike in the lake (stupid, stupid...!) to get the mud off it. I won´t dip it again but how do I solve the squeeky-squeeky?
    Manne.
    I like playing in the water, seeing what I can and cant cross....sounds like we ought to avoid that much water huh lol!
    Huge Tracts of Land
    Reputation: Mtbrat's Avatar
    you should take off one of the zip ties and have a look, you will probably need to lube an/or grease the bits that need it --> refer to your manual or check out www.cannondale.com tech bit
    :O)
    yeah I found an article on cdale site after I posted here. second time I looked (after posting) I found it. thanks for the tip
  1. 03 Spec Enduro Comp or 04 Spec Enduro Pro?
    By Val_Wolfe in forum Specialized
    Last Post: 08-15-2004, 04:12 PM
  2. 03 Spec Enduro Comp or 04 Spec Enduro Pro?
    By Val_Wolfe in forum Bike and Frame discussion
    Last Post: 08-14-2004, 07:56 PM
  3. Elsworth Dare... hit or miss?
    By Korrupt in forum Downhill - Freeride
    Last Post: 08-13-2004, 08:17 AM
  4. 03 or 04 Brain? Should I be suspicious?
    By Odie in forum Specialized
    Last Post: 06-06-2004, 11:19 AM
  5. 04 Stinky, 04 BigHit? or 04 Atomik?
    By Phil_Mosco in forum Downhill - Freeride
    Last Post: 05-13-2004, 12:29 AM
