Results 1 to 6 of 6
    Reputation: crazee horse's Avatar
    Sep 2012
    sl series brakes................
    ok, i gotta 2012 sl4, with helix brakes. i changed the pads to sintered, and have been noticing that well after a couple months of riding (2-3 times a week) the rotors are scratched up like nobodies buisness................. is it because they are low quality metal ? ive seen some nice alternatives on ebay, and am tempted to give them a go.....................
    Hayes V6 (Y12) Disc Brake Rotors 160mm SINGLE / PAIR T25 Bolts FREE POST - NEW | eBay
    o<o NYC pebble jumper!
    Reputation: skene's Avatar
    May 2013
    Sintered pads are semi metallic... So those scratches are from the metallic compounds within the pad scratching your rotor. You can change the rotor, but as if you still are using sintered pads you will achieve the same effect.
    Sep 2012
    Hmmmmm what pads would you recommend next ?
    Reputation: MarinCRO's Avatar
    Jul 2013
    I know shimano makes "Resin pads only" rotors, and regular rotors which are probably hardened and made to work with (semi)metallic pads.
    May 2013
    If your rotors are equipped with resin pads, you always want to stick with resin pads. They generate less heat and will not overheat any oil and seals that would not normally be affected by heat generated by any organic/resin (for hydraulic brakes). However semi metallic would end up conducting heat and transferring over.
    Sep 2012
    Fitted my new rotors, and they rub slightly, hopefully after a good ride they will be okay as the helix brakes don't have adjustment.
  1. 2013 29er series vs. The x-cal 2014 series
    By Ken Borchardt in forum 29er Bikes
    Last Post: 09-13-2013, 06:28 PM
  2. Wisconsin Fat-Bike.com Ride & Race Series (6 Race Series!)
    By ~gomez~ in forum Minnesota, Wisconsin
    Last Post: 03-23-2012, 05:30 PM
  3. Cane Creek 110-series worth it over 40-series?
    By equalme in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-13-2011, 08:59 AM
  4. New M series Magura brakes
    By Harryonaspot in forum Brake Time
    Last Post: 06-21-2011, 09:57 AM
  5. Replies: 10
    Last Post: 06-16-2011, 12:09 PM
