Results 1 to 7 of 7
    Dec 2012
    SI SL vs SL MTB Crank
    Hey,
    am a little confused as I do not find any infos: What is the difference between SI SL and SL Crankset for MTBs? I have a SL on my Scalpel Team 2012 and on my 2013 F29 Ultimate I have a SI SL although on the Cannondale Website it mentions SL Crank. They seem to look fairly similar...
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    They're the same. In 2012, there was only a Hollowgram SL model. For 2013, there are three models, all names now start with 'SI'.
    • New for the 2013 model year is a cheaper/heavier Hollowgram SI (3D forged, not two halves machined and bonded like the others)
    • There is yours, the SISL (same as last year's SL, just a different name)
    • There's also the new SISL² which is an even lighter version of the SISL with different machining to remove more material while keeping the excellent stiffness
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Dec 2012
    Reputation: BoostN7's Avatar
    Dec 2010
    Can always count on Dan Gerous to answer questions on all things Cannondale
    and no, I am not missing the other half of my fork....
    LA CHÈVRE
    Quote Originally Posted by BoostN7 View Post
    Thanks.
    Maybe I should apply to work for Cannondale's tech support.
    Dec 2010
    Okay okay, for double points. Who makes C'dales frames? I thought I heard that they were made by Merida?
    LA CHÈVRE
    I doubt, Merida being part owner and the manufacturer of Specializeds, I don't think Cannondale would want them to be responsible for their products... maybe the lower end frames but probably not the higher end ones.
  1. Replies: 28
    Last Post: 02-02-2015, 09:24 PM
  2. Help upgrading Shimano 8spd IG crank to 9spd HG crank.
    By kryten in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2013, 05:40 PM
  3. should i spend the extra $100 and get the xt deore 2x10 crank over the sram x7 crank
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 11:27 AM
  4. Replies: 1
    Last Post: 03-11-2012, 06:18 AM
  5. loose crank, rounded taper..bottom-bracket & crank damaged?
    By chimpanzee00 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2012, 03:21 PM
Members who have read this thread: 4
