Results 1 to 6 of 6
    Shock pump for lefty
    Which shock pump (brand / model) you guys are using for the lefty? My off brand shock pump's needle is a bit short for the PBR 140's schrader valve even though it works fine with the Fox shock... Thanks for any input.
    Sweater
    Reputation: Buzzaro's Avatar
    Quote Originally Posted by hypercycler
    I have a Fox that works just fine. Even better though is the Topeak, its got a valve isolator so that you don't lose any pressure when attach/unattach the pump from your fork or shock. It fits the lefty also.
    All out of S**** and down to my last F***
    I'm Riding It
    Apr 2005
    +1 on the topeak
    www.bikeride.ca
    Alberta born-n-raised mountain bike racer.
    Reputation: karlmichael's Avatar
    Take your fork in and have them back out the valve 1/2 a turn and your shock pump should work
    A guy on a bike Moderator
    Reputation: TobyGadd's Avatar
    Thanks guys. Went to my LBS, they don't have the Topeak, well got a cheap looking Bontrager instead and it works flawlessly.
