Results 1 to 12 of 12
    Jun 2010
    Shimano cranks on BB30 shell
    I am mooving to a 2010 RZ One20 frame. It has a BB30 shell and I am looking for a solution to continue using my current LX cranks.
    I found a number of solutions, such as:
    - FSA adapter to be pressed into the BB30 shell and allows fro use of any "standard" crankset
    - Wheels Manufacturing BB30 Shims for HollowTech II, looks very easy to install - these are pressed into the BB30 bearings
    - FOCUSTEK BB30 MTB Adapter, these look like a BB30 bearing with an extra shim
    Any recommendations? Good / Bad experience with any of these?
    Thank YOU,
    Fredy
    I've got the Wheels Mfg adapters on my Flash 29 using an SLX crankset and a SRAM BB30 bearing kit. Works great. Had the LBS do the installation because it was a warranty replacement frame. I was told a spacer was placed on the drive side to maintain chainline.
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    kcnc too does this adapters
    reset from Germany too
    THM Carbones too
    and others not remembering
    lots of chioce
    I use the Wheels Mfg adapters on my Caffeine 29er and SLX cranks, too. Works great, no problems.
    I have just received a replacement Flash carbon ultimate frame, on checking the BB30 bottom bracket shell has an integrated circlip (unremovable) any ideas on if there is a shim available that will adapt this style of shell to accommodate a standard Stylo triple crank set.
    Jun 2010
    Well, I got the shims - now I need a couple of 2.5-3mm spacers for the 24mm spindle.
    Any idea where to buy these online?
    Thanks,
    Fredy
    gmk
    gmk is offline
    angels get bald too
    Reputation: gmk's Avatar
    Quote Originally Posted by NZL151
    sorry but
    why donīt you use the BB30 on your flash ? fsa(BB30) cranksets are reliable and stiff and light too
    "Show your bike some love and it will show the love back."
    Eric, niner bikes
    the most important vehicle is a 29er bicycle
    I got the Focustek adapter for my new Rize, works like a charm with an XTR crank. Was a bit iffy to press it in (no Cdale tools here), but with a good headset press I got it in eventually. Good, high quality product.
    Reputation: baalan's Avatar
    Nov 2007
    It's unfortunate that Shimano refuses to adopt the BB30 or a double crankset for that matter other than ultra expensive XTR for 2011. It's one of the reasons I'm thinking of swinging towards 2011 Sram X9. I don't need a triple crankset, I never use the granny and I'm in average shape .
    '96 Uber Light
    '00 R3000 TT
    '08 Six13
    FIRENZE rulez !!
    yes http://wheelsmfg.com/content/view/785/54/
    Quote Originally Posted by fredy_signer View Post
    Thanks,
    Fredy
    I believe the shims/spacers are needed to make the width 73mm. When ordering this adapter for a mtb you also need to order the $10 spacer kit.
    Quote Originally Posted by gmk View Post
    sorry but
    Yes, it's your bike of course but why the stylo / triple? surely you'd want a nice BB30 (Hollowgram?) or something on an ultimate?
