Results 1 to 14 of 14
    Scalpel w/ Carbon 140 Lefty Max
    So, I have a 2009 Team Scalpel and love the way it climbs...but every once in a while (which seems to becoming more often) I crave a more plush front end. The 110 SL SPEED just doesn't handel the bumps like a 140 RLC. Has anyone ever tried a 140/Max on a Scalpel? I am wondering how much it will effect the handling due to the headtube angle. Thoughts.
    Reputation: Sacke's Avatar
    Interesting question... Was wondering what the Lefty 120mm would do to a 2011 Scalpel.
    Reputation: nathanbal's Avatar
    get a 110 RLC. plenty plush. 140 will slacken the front end too much.
    Feb 2005
    If you love the handling as is, like Nathan said, it will affect the HTA in a way that you may not like. It'll slacken about a degree, and feel more wandery than before.
    You could also install a 2011 PBR damper in, much more tunable than your current cartridge, or, if you've never had the fork worked on, it may just be old tired, and dried out.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    A 140 Lefty would also probably void the bike's warranty... Just get a cheap rigid bike and ride it a while, then a Scalpel feels like a couch!
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    What is the process for getting a PBR into a TCL body?
    Feb 2005
    Quote Originally Posted by troutrover
    TCL?
    - FrostyStruthers
    Fat fingers...was supposed to be RCL.
    Feb 2005
    I've lost track this tidbit in my head, but I'm 98% that the Fox Leftys have a larger bore, (may just be the Terras, so don't quote me) necessitating leg replacement with cartridge upgrade.....
    - FrostyStruthers
    Quote Originally Posted by MendonCycleSmith
    of course he could switch the steerer to a lefty4all and use a canecreek angleset to adjust the headangle accordingly
    expensive workaround though
    LA CHÈVRE
    Quote Originally Posted by danridesbikes
    And still, the axle-to-crown distance would be too much for the frame...
    YB1
    YB1 is offline
    What about the 2011 Lefty Ultra120 PBR? That should work on '09 Scalpel right??
    Emory Kalahari Kruiser
    Quote Originally Posted by YB1
    I just looked through the Scalpel user manual today, and saw that 500mm was the maximum allowed fork length. (axle-bottom of head tube)
    The Lefty 120mm has 490mm fork length, so it shouldn't be a problem.
    Anyone try that yet? How much does it change the head angle?
    I just put the RCL 140 on my Scalpel and took it for a ride. Axle to crown is 515mm. Handling is a little slower (not by much) than the 110SL but a 1/2 hr in I had a feel for it The bump response was much improved. Will report back after some more saddle time with some pictures.
