Correct. You can use the DT hub with Lefty 2.0 and the correct brake adapter for the hub. The spindle lengths are the same on all Lefty and Supermax. The rotor placement is shifted toward the leg on the Lefty 60 (Supermax/Lefty 2.0) hub.
The classic Lefty hub is 50 mm. The spindle starts right from the middle of the fork in Lefty 1. Lefty 2.0/Supermax 2 hub is 60mm and in the fork the spindle starts from the side. You can use the classic hub with Lefty 2.0 with a different break adapter.
But the new wider Lefty 60 will enable a bigger spoke dish angle >> brace your rims better, so generally try to stick with the Lefty 60 rather than the legacy Lefty 50.
The old hub will fit on the new fork (with above adapters) but the new hub will not fit on the old fork.
It's not a fancy adapter, it's just a different model Cannondale brake mount. I had to buy one because Stans is still using older hubs and I didn't know that when I ordered my wheels. I'f rather have the wider hub if course, but it wasn't a deal breaker.
I can use my existing DTSwiss 240 hub (off my 2013 lefty hybrid) on a new Lefty 2.0 if I buy the correct brake adapter, even though the spindle lengths of the axle are different? (from what I understand?)
Alternatively you can just use a 6mm spacer on the disc flange and longer rotor bolts (aka boost adapters) then you keep the lefty 2 brake caliper adapter and you can then just swop wheels between a lefty 2 hub and a std lefty hub.
The Lefty 1.0 hub is 50mm across the flanges.
lefty 2.0 hub is 60 mm across flanges.
That's 10mm difference in width I haven't measured the distance between bearings in the two hubs to give you an idea of the length of the stub axle and if that's different from 1.0 to 2.0
I do know the 2.0 hub is not compatible with the 1.0 fork. There is a spacer kit available from cannondale for the 1.0 hub onto 2.0 fork
Like the previous poster, I'm also trying to confirm what the "thickness" of the spacer required is.
My situation is below;
Currently running a Hybrid 2.0 fork (55mm offset) with a KH112 adaptor running Lefty 50 hubs. SDweet !
Even sweeter, is grabbed a CarbonTi hub at a bargain price, but it's a Lefty 60 size.
So, to run both 60 & 50 hubs on the fork, I need to change the brake adaptor to a KH111 (so the new hub fits fine), but get the spacers to go between the disc and hub to run the Lefty 50 hubs. Correct ?
If so, I've seen one supplier of these spacers - Lefty SL hub to 2.0 fork adaptor from Stage 21 cycling, but it's just ridiculously expensive.
Any knowledge of actually how thick these are, as can find other options around the 4.8-5mm mark that may do the job as well.
Cheers
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
