    Scalpel - Chain Length
    Having just built up a Scalpel I was wondering what is the correct chain length, in terms of number of links.
    The frame is a medium, 44-32-22 chainset, 11-34 cassette, Shimano XTR long cage rear derailleur and a SRAM PC991 chain.
    Thanks in advance.
    Pete
    Reputation: rumshcawheely's Avatar
    As with all bikes you build, just drape the chain as if you are cross ringing big ring (front) to big cog (rear) and have the chain overlap itself by 1 or 2 links. The object hear is to make it long enough so that it won't break your rear der. or get stuck in that gear if you ever stick it in that big to big combination. Be sure when you "drape the chain" you run it as it is supposed to run through the front and rear derailleur.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I size mine that way but direct, without passing through the derailleurs...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    Me too, but while advising someone who hasn't done it before, I don't want to allow him to cut the thing too short. By the way Dan funny pic of Bush (but I guess those are easy to find) and that snowboard company quote is pretty clever.
