Results 1 to 12 of 12
    my church is the woods
    Reputation: moonraker's Avatar
    Scalpel carbon downtube protection?
    Does anyone know of a down tube protective cover, a molded piece of sorts, that is designed to fit the Scalpel carbon 29er? I looked at cannondaleexperts.com, they have them for the Jekyll carbon and other models, but nothing for the Scalpel.
    Several friends have damaged their down tubes, smacking log-overs and other obstacles on trail, just in front of the chainrings. Here's pics of one:
    Scalpel carbon downtube protection?-imag0247-medium-.jpgScalpel carbon downtube protection?-imag0248-medium-.jpg
    Unstable Corruption
    Reputation: 0xDEADBEEF's Avatar
    Oct 2011
    you may try Skean Morpho, a great universal rubber thingy, it does protect the frame and available in different colors.
    it can be fitted to almost any frame, just need some time and a sharp knife to cut it for a perfect fit.
    Scalpel Fan
    My LBS put this on my Carbon 1 before I took delivery. Been happy with it so far. It is just a generic shield.
    Think you need a KP054, would this do the job?
    https://qwerty-cycles.myshopify.com/...uffguard-kp054
    I use this on my scalpel, only had the bike a couple months in winter, but it seems to do the job so far:
    Shelter Bike Frame Protection
    Dec 2012
    Well guys, these kind of carbon protection for any model is what a local store is doing www.pulse100.gr
    Attached Thumbnails Attached Thumbnails Scalpel carbon downtube protection?-20130221_174652.jpg
    Dec 2004
    2014 Scalpel
    Quote Originally Posted by moonraker View Post
Name:	IMAG0247 (Medium).jpg
ID:	771500Click image for larger version.
Name:	IMAG0248 (Medium).jpg
    Recently I walked into my local Cannondale shop and saw that 2014 models now come with a plastic downtube protector stock. It looks pretty slick, it's plastic.
    Interestingly enough it looked like all the 2014 models including hardtails now come with heavy duty downtube protectors.
    local LBS can probably order 1 for your Scalpel 29er...
    Oct 2007
    My 2013 scalpel 1 had damage there too. I had a carbon repair done and it was a perfect repair. Paid him for the job only to get home, was showing a friend, and he notice a hairline crack at the shock mount and top tube. Keep an eye on those shock mounts. I need to look into some downtube protection.
    Dec 2004
    Quote Originally Posted by norty_mtb View Post
    Did you know Cannondale has a lifetime frame warranty, I've never had issues with getting a free frame replacement in the past. As long as you are the original owner then you've pretty much got yourself a free frame replacement.
    Oct 2007
    Fully aware of warranty. Lifetime if it's a manufacturers' defect like with my shock mount. As with most of these frames that are damaged in this spot, mine was probably caused by a rock getting kicked up. Its a pretty exposed area. Most of these are not JRA cracks. But who knows?
    Bottom line is some protection there is a very good idea and Cannondale will take care of the majority of frame issues.
    Hi.
    Just to keep you inform that Skean Bike is now available in the USA and distribute by BTI USA. 😀
    Stéphane
    does anyone make a protector for the Scalpel Si?
Members who have read this thread: 31
