Results 1 to 5 of 5
    Nov 2012
    Scalpel Carbon 2 - Tire suggestion
    Just picked up a new 2013 Scalpel Carbon 2. On the maiden voyage the rear tire caught a sharp rock that put a 1" slice in the side walls. I was running tubless, so went completly flat. Good think I had a spare tube. Tire is booted for now and working ok, but wont last long. Will need a new tire. Any suggestions on a more durable option than the Racing Ralphs?
    Reputation: StumpyElite2010's Avatar
    RoRo/RaRA Snake Skin ?
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Reputation: Flash29r's Avatar
    May 2013
    There is actually two versions of the Racing Ralphs. I had a set that came with my Flash when I bought it new. I ended up replacing the wheel set with a brand new take off set of Reynolds from a '13 F29 which had the lighter weight Ralphs like you apparently have as well and I had the same thing happen to me. Side wall blew out due to a sharp rock. I have my old Ralphs and they have a heavier sidewall as well are slightly heavier tire. If you like the Ralphs as I do for the tread pattern, just look for the heavier ones and you should be good. Any light weight racing tire is gonna have the same issue you just went through no matter the brand.
    Happy Trails
    Reputation: Scott In MD's Avatar
    I took the RaRa's off mine at the shop, and replaced with two 2.2" Maxxis Ikon EXC Evo's for mostly dry, rocky Arizona desert XC riding. I don't know what EXC abbreviation stands for, but this version is a little more durable than the non-EXC version. In any event, I've had good luck with them so far.
    Nov 2012
    Thanks. I just swtiched to a set of Maxxis Ikons with the EXC, which i guess is some extra sidewall protection. The sidewalls seem much more durable than the Racing Ralphs. Plus, tubeless set up was easy. I was able to set them with a floor pump, which is nice. We'll see on they perform. Thanks to all for the suggestions. Loving the Scalpel. Extremely quick. Still dialing it in.
  1. Tire suggestion
    By sblake in forum 29er Components
    Last Post: 12-22-2012, 08:39 AM
  2. Need 26 er Tire suggestion
    By MadMacMan in forum Wheels and Tires
    Last Post: 10-22-2012, 08:59 PM
  3. Replies: 1
    Last Post: 03-05-2012, 06:30 AM
  4. Tire suggestion
    By MI-29er in forum Commuting
    Last Post: 12-30-2011, 08:47 AM
  5. 29er Tire suggestion
    By dutchman59 in forum 29er Bikes
    Last Post: 10-07-2011, 08:49 PM
