Results 1 to 13 of 13
    Scalpel and BB30 XX crank - will it work??
    I've searched the forums and also contacted Canondale but can't seem to get a definitive answer. Will the SRAM XX BB30 crank fit on a 2009 Scalpel?? Anyone know for sure? Has anyone installed an xx crank on a Scalpel?
    Here is what I got back from C'dale:
    Road 142mm +/- 2mm
    Mnt 172mm
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    The one with the wider q-factor fits for sure, the narrower one, I don't know...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Cannondale Maros Team
    Reputation: vladxc's Avatar
    Jan 2009
    I had the wrong topic to answer. Sorry !
    My mistake
    I think the XX only comes in one q-factor 156 (?).
    LA CHÈVRE
    It comes in only one chainline but two different q-factors.
    as far as I can tell, there is only one q factor offered for the xx (156Q). did you see another listed some where? I wonder what q factor the hollowgram si and k-force cranks are...
    http://www.sram.com/truvativ/product...speed-crankset
    Feb 2010
    Quote Originally Posted by Dan Gerous
    OK ..learning moment for me here ...Q FACTOR ?
    LA CHÈVRE
    jrock: They are available in 156 and 164 q-factors for the BB30 models. Chainline is always the same whatever the model.
    BadBoyNY: Q-factor is the overall width of the crankset, the bigger the q-factor, the further apart will be your feet. On the graphic below, the q-factor would be W4 x 2 + the thickness of the crankarms...
    Attached Thumbnails Attached Thumbnails Scalpel and BB30 XX crank - will it work??-xx_crankset.jpg
    great info, thank Dan!
    So, which do our scalpels take? Q156 or Q164? My calculations, it's the Q164. Looks like the 156 might work but clearance would be tight.
    thanks again for the posting the image above...
    Reputation: unkosama's Avatar
    Anyone ever try the XX Q156 on a 2011 Carbon Scalpel? My FSA Afterburner is about done, and I am thinking about a XX, and would prefer the tighter Q-Factor. But want to be sure before I order it.
    Oct 2007
    Quote Originally Posted by unkosama View Post
    I have a 164 on my 2011 and it is tight. I'll get a measurement of clearance later today. I think a 156 would be too tight and the rub under heavy loads.
    Oct 2007
    Quote Originally Posted by norty_mtb View Post
    5mm of clearance
    I have the XX with Q156 on my 2011 Scalpel with no issues at all so far. I've gotten about 80 miles on the setup at the moment...
