Results 1 to 12 of 12
    Mar 2012
    New question here. Scalpel 29er sizing: M is Large?
    Hi,
    I am 6' tall and have and 34.3'' inseam.
    I tested L size and M and i am leaning towards the M size.
    Checked with bike fitter and he says "Go smallest possible" i.e. "Go M".
    Sizes are S M L and XL.
    At 6' i should go straight to L, no? I wonder who will use the XL?
    My measure from seat end to mid of handlebar is 56cm on M and 58.7cm on the L.
    Is the Scalpel 29er designed to be ridden in a more stretched position?
    Any help? Lots of money at stake, and would like to do the right choice
    Did anyone else of my size go with M instead of L?
    Reputation: StumpyElite2010's Avatar
    Strange... for your profile I am pretty sure the large should be the right frame.
    I am 5'-10" with 32" inseam Riding large Scalpel and Flash with no change to stem length
    I also rode Large Specialized SJ and large Niner all seems to fit great.
    I'd rather have a bit of a large frame than a too small one.
    As for the large frame you can adjust your fit with different stem and saddle position and for a too small one you are screwed...
    Truth is that I test rode the Medium Scalpel around the block and it seems like it will work too, but since I had a bad experience with a medium 26er bike, and all my other bikes are large, I decided to go with the large.
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Reputation: MarinCRO's Avatar
    Jul 2013
    I'd say Cannonales are bit on the shorter side if anything (compared to Specialized).
    I ride Epic 26er (L) and it fits very well, but few weeks ago I got to ride friend's Scalpel 29er (L) which felt a bit short compared to the Epic and I would prefer XL if I were to buy one.
    I'm about 189-190cm (so about 6' 3").
    Similarly, I got Trigger 29er in XL which despite being longer than Scalpel has shorter stem and overall reach is probably the same or even slightly less on the Trigger.
    Considering Scalpel is a more of a marathon-XC bike, it would make much more sense to go slightly bigger than smaller.
    Friend who rides it is about 180cm, and it fits him very well.
    Nov 2012
    Quote Originally Posted by wawando View Post
    Hi,
    I'm 6'2" with a 34" inseam and went XL. I'm a long-time road racer, and like the extra stretch in the cockpit. This was my first year racing off-road, and thought the larger size would also be more stable for my newbie bike handling skills.
    Mar 2012
    Thanks for the feedback. It seems i am alone
    The measures i have on the M are the ones i had on my previous Scott Spark L and on my road bike.
    Today i will test both again and see the outcome
    Reputation: nathanbal's Avatar
    road bike geo does not equal mtb geo.
    Mar 2013
    First, compare the top tube length of the Scott Spark (that you know you fit on) to the Scalpel. If theyre both the same, then the difference in feeling is probably a combination of saddle rail placement, stem length and angle, and handlebar width, rise and sweep....
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Jul 2013
    Quote Originally Posted by Eric Marshall View Post
    Looking at OP inseam length to height ratio, it might be that he's got relatvely short torso which might mean M Scalpel would fit well.
    It would be the best to try it side by side.
    Mar 2012
    I just did a 4h side by side ride.
    Both felt ok.
    Large feels more "spacy" and M smaller. As expected ))
    No new info... How do i know what is the best choice...
    Nov 2012
    Both felt ok.
    If you're only going to use the bike for full-on racing, and you already have a lot of trail experience, go with M, otherwise go with L.
    Happy Trails
    Reputation: Scott In MD's Avatar
    6-1 (185 cm) on a Large Scalpel with the OEM 110mm / -15 degree stem swapped off and replaced with a 100m /-5 degree stem. Everybody's perfect fit is different but I would think a Large is best for most 6-footers.
    Mar 2012
    Thank you very much!
    That is the decision i had last night: L with -5 stem 90mm
  1. Replies: 0
    Last Post: 05-06-2013, 05:03 PM
  2. Replies: 0
    Last Post: 05-06-2013, 05:02 PM
  3. Scalpel 29er sizing question
    By mark43 in forum Cannondale
    Last Post: 12-16-2012, 07:14 PM
  4. '12 Scalpel 1 large 29er frame for sale in classifieds
    By bikesinmud in forum Cannondale
    Last Post: 10-08-2012, 05:56 PM
  5. Scalpel 29er sizing at 5'11"
    By Jaybo in forum Cannondale
    Last Post: 05-30-2012, 10:14 AM
