Page 21 of 21 FirstFirst ... 11 17 18 19 20 21
Results 501 to 506 of 506
  1. #501
    Reputation: packfill's Avatar
    Aug 2005
    Quote Originally Posted by dakotakid View Post
    I ran into the local Cannondale rep at a trailhead here in SLC the other day. He had the Scalpel 2 and had increased the travel to 120 and put the cup on the bottom. He said the climbing ability took a little hit but absolutely loved the downhill with these changes. I might do it.
    my understanding is that the lefty's axle to crown is fixed, so increasing travel wouldn't actually alter the ride characteristics. All it would do is let the wheel come closer to the frame. Anybody...anybody?
  2. #502
    Ive stretched the lefty out as well. The mod is actually more like 110 not 120. Wheel closer to frame? If anything is 10mm further away. The fork is still bottoming at the same point.
  3. #503
    Quote Originally Posted by packfill View Post
    k51 is right. According to the Cannondale rep and my lbs, the increased travel comes from lengthening. It is not from increased travel within the Lefty getting "closer to the frame." The lengthening would increase the wheelbase with the commensurate handling changes, and it would make climbing characteristics less desirable. As with my post of a few days ago, these may or may not be noticeable, but the rep. was enthusiastic about the downhill performance of the increased travel. He encouraged me to increase my sag in the Lefty to maximize the current (100mm) travel. I had 115 psi (weigh 170 no clothes) and dropped it to 105 before the ride tonight. Loved the difference and it didn't bottom out. Just dropped it to 100 and will try it tomorrow after work. I can't imagine going less than 100 for my weight. Cheers, and enjoy these fantastic bikes!
  4. #504
    Scalpel 29 Ride Report
    I would agree that more sag for All around riding on the fork makes for a better trail experience. I use the Scalpel as a quiver bike. Moving the spacer to the bottom coupled with the extra travel, puts the head angle at just under 70 deg(iPhone app measured). I'm still playing with pressures but the added travel and matching sag has improved small bump compliance noticeably.
  5. #505
    Quote Originally Posted by t51rmkiv View Post
    What are the effects on climbing characteristics resulting from the combination of changes? Just noticeable, somewhat annoying or large changes in uphill handling?
  6. #506
    The short answer is just noticeable. Riding style will play a factor. I'm on a single speed for 80 percent of my riding so take my consideration with a grain of salt.
    The biggest concern you should consider is the parity between seat and handle bar height after making any changes. My setup is 90 -5 stem, 720mm flat bar with 2 stem spacers, no setback seat post, coupled with the bottom spacer and added travel. This puts my seat height even with the bar height. Bike is a large and I'm 6ft
  1. Replies: 15
    Last Post: 07-24-2011, 03:38 PM
  2. Anyone ride the 2011 scalpel yet?
    By guvna in forum Cannondale
    Last Post: 06-27-2011, 12:46 AM
  3. Replies: 29
    Last Post: 11-14-2007, 06:02 PM
  4. From Scalpel to Rush. the first ride...
    By Anders in forum Cannondale
    Last Post: 09-11-2006, 07:46 AM
  5. 1st ride on my Scalpel..this season
    By subzero in forum Cannondale
    Last Post: 04-26-2006, 05:01 PM
