Results 1 to 9 of 9
    Dral
    Jan 2018
    scalpel 2017 frame cracked
    Hallo Folks!
    My scalpel si -4 carbon 2017 frame mysteriously cracked at the lower joint of the rear triangle at the drive side.
    There was no jump or a fall to blame.
    I just notice the crack with just 1200 km.
    Does any one had similar issue?
    The bike is brand new and i am really worried.
    I will try to put a picture later on.
    Attached Thumbnails Attached Thumbnails scalpel 2017 frame cracked-dsc_6060_rdc.jpg
    Mar 2015
    Pictures will help a lot. Did you contact your LBS?
    Dral
    Jan 2018
    Well i contact with the dealer and Cannondale arrange for a frame replacement.
    Dral
    Jan 2018
    I 've just posted a picture, the bike is upside down.
    i had also experienced the issue with the loosen bolt from this side.
    i have tighten the both to 5nm and also use thread lock
    Reputation: Chrizzzz's Avatar
    Feb 2016
    I had the same issue after 5 months.
    Main pivot bearing. But didnt know if it was the paint or the alloy-insert.
    Cannondale send me a new frame.
    Instead of a '17 team-frame i got a '17 race-frame.
    For sale:
    - Cannondale 2x Spider XX 120/80
    Mar 2015
    Quote Originally Posted by Chrizzzz View Post
    Those are identical frames (both Hi-Mod), only paint job is different
    Dral
    Jan 2018
    well they look identical, this is on the non drive side though. So i guess this might be a "weak spot" of the scalpel frame. My frame replacement is still on going so i dont know if they will replace it with the same or better frame. My frame is the scalpel -4 Did you had any problems with the new frame?
    I had the same issue after 5 months. Main pivot bearing. But didnt know if it was the paint or the alloy-insert. Click image for larger version.
ID:	1177408 Cannondale send me a new frame. Instead of a '17 team-frame i got a '17 race-frame.
    Sep 2016
    Mine cracked on the driveside seatstay after a little more than six months. The crack was on the driveside top lock'r mount (around the metal insert) on the inside, so i accidentally saw it when I disassembled the swingarm.
    Cannondale quickly provided me with a new swingarm.
    Feb 2016
    Quote Originally Posted by samarskyrider View Post
    Yes, but its not the same colour
    And a Race is not a Team if you think of re-selling.
    Because of the black-paint and only a 1000k i dont know if there are any cracks or hinds i have to worry about.
    But for sure i will take a look if the racing season will start @the end of next month.
    For sale:
  1. 2017 Specialized Epic Comp Carbon vs 2017 Cannondale Scalpel Carbon 4
    By hammonjj in forum XC Racing and Training
    Last Post: 03-03-2017, 03:32 PM
  2. Replies: 6
    Last Post: 01-15-2017, 03:11 PM
  3. Replies: 15
    Last Post: 12-23-2016, 08:43 PM
  4. Replies: 12
    Last Post: 11-21-2016, 08:14 PM
  5. Cracked Cannondale Scalpel 29er 1
    By YT in forum Cannondale
    Last Post: 02-01-2012, 12:31 PM
Members who have read this thread: 17
