Results 1 to 6 of 6
    Reputation: eric_syd's Avatar
    Scalpel 1st generation shock: help needed
    I am just finishing the build of my Scalpel 1st generation.
    The rear shock is a Fox Float RP3.
    I'm 110kg, what pressure should I put in it ?
    At 170 psi, the sag is still very impressive. How much higher can I go ?
    Oct 2007
    Ask a good LBS because that bike only has a little travel to it for total XC purpose.
    Reputation: sp3000's Avatar
    Or you could just run the recommended 25% of sag on the shock.
    Pic is from the 2000 Scalpel setup guide.
    Attached Thumbnails Attached Thumbnails Scalpel 1st generation shock: help needed-screen-shot-2011-10-17-10.18.19-pm.png
    Quote Originally Posted by sp3000 View Post
    Thx sp3000.
    I had actually read that manual. My sag is more in the 12mm with 150psi right now, so I assume I would need to go roughly up to 225psi if I want to be back at 8mm.
    Is it safe to run 225psi on a Fox RP3 ?
    Yes it is fine - see extract from Fox manual below.
    If you PM me your e-mail I'll happily forward all the PDF documents I have on the subject.
    Attached Thumbnails Attached Thumbnails Scalpel 1st generation shock: help needed-screen-shot-2011-10-19-10.20.20-am.png
    I need a new shock pump then....
  1. Replies: 2
    Last Post: 03-16-2009, 03:28 AM
  2. Replies: 22
    Last Post: 12-01-2007, 09:41 PM
  3. Replies: 5
    Last Post: 04-07-2007, 06:07 PM
  4. New (generation) shock
    By ban in forum Downhill - Freeride
    Last Post: 12-04-2004, 08:29 PM
  5. new (generation) shock
    By ban in forum Shocks and Suspension
    Last Post: 12-03-2004, 09:18 AM
