Results 1 to 6 of 6
    Save seatpost length out of seat tube?
    I am thinking of giving my back a little help when I ride my F600 and the Save seatpost seems to be a good idea but... not sure I have enough length out of the seat tube to make the Save flex work properly
    Anyone could tell me the minimum length of seatpost I need out of the seat tube?
    Well... I didn't find the info on the web and apparently nobody knows here... I may go for a titanium seatpost instead.
    Reputation: BoostN7's Avatar
    Dec 2010
    Lower your tire pressure, and take a look at your bars.
    and no, I am not missing the other half of my fork....
    How much tube do you have out at the moment?? I would suggest 200 - 250 is the minimum
    You can have out??
    The total length is 420mm and it changes shape half way up.
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    you have to check seatpost and frame, both.
    every seatpost has a minimun insert sign, normally 9-10-11-12 cm from the bottom
    every frame requires a ... cm inside the seat tube to avoid failure. ( Flash requires 9 cm inside ).
    mix and match these two values :-)
    this is on Cannondale site but doesn't help so much:
    http://media.cannondale.com/media/Ma...echnote_en.pdf
    this is more helpful:
    http://media.cannondale.com/media/F-..._126709_EN.pdf
    check on page 7,8,9
    I knew for the minimum insertion, actually, the missing info was the maximum insertion which is... on page 9, second link from Eliflap. It's for a 350mm long post but the flexing point doesn't change for a 420mm, the post is just longer to gain on the minimum insertion.
    Result: the minimum lenght out of seat tube to make the Save work properly is somewhere between 18 and 19 cm... and I have 19,5 cm available. So it's supposed to work but I'll confirm later in a bike shop.
    Thanks Flying_Scotsman and Eliflap.
Hot Deals
Contests
Latest Mountain Bike Articles
