Results 1 to 5 of 5
    Mar 2012
    same rims for '12 flash and '14 scalpel?
    I have a 2012 Flash alloy 1 and I have the stock rims and tires as well as stans arch tubeless rims. I am going to pick up a FS soon and I am wondering if the stans would fit on a scalpel? If so I may also pick up a set of enve rims and using them on both bikes would be a plus.
    Epic Flash Boris F65X + road bikes
    Mar 2012
    Quote Originally Posted by Flucod View Post
    You would need end caps for the Scalpel. The rear is 142 x 12, Flash rear is a 135QR.
    Im not being a smart A$$...is that a yes or no? I am guessing it works fine just wont be QR when on the scalpel....is sharing rims between bikes doable other than that?
    Reputation: StumpyElite2010's Avatar
    As Flucod said, the rear hubs axle is different between the Flash and Scalpel.
    So no, it wont work, unless you can find an adapter/axle converter kit specifically for your hub that will convert the hub interface from 135 QR (5 mm Quick release) to 142 x12 which is 12" mm axle.
    These kits are specific to your hubs.
    So the short answer: you cannot just remove the wheels from the Flash and install on the scalpel without modification.
    The issue is not the Rims... but rather the Hub Axle specification which is different
    You may want to read this article about the 2 different standards
    The first pictures shows the 2 axles side-by-side
    Tech Speak: 14212, What?s the Big Idea?
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Mar 2012
    Thank you stumpy!
  1. Med Scalpel to Large Flash Fit
    By afdude in forum 29er Bikes
    Last Post: 02-17-2013, 08:55 PM
  2. Scalpel vs. Flash...which do you prefer?
    By dardeca in forum Cannondale
    Last Post: 10-07-2012, 05:45 PM
  3. Possible Flash 2 in my future, or Scalpel
    By Cormac in forum Cannondale
    Last Post: 07-08-2012, 03:31 PM
  4. Moving 90mm PBR from Flash to Scalpel
    By 58teeth in forum Cannondale
    Last Post: 05-19-2012, 04:43 AM
  5. Help - Scalpel vs Flash - Sizes
    By Not-4-You in forum Cannondale
    Last Post: 07-22-2011, 04:17 AM
